Identifying Capacitor for my Graphics Card
  • FlyingMammalMan
    • Nov 2014
    • 7
    Hello All,
    I've been slaving away googling on where to find a replacement for my capacitor. I stupidly ripped one off when replacing the stock cooler on my graphics card with the NZXT Kraken G10.
    Anyway, I've attached the pic of the bad cap. If you guys would help at least identify an exact replacement that would be great. I would just need all the specs of the cap, such as the microfarads and the voltage and all that. If you can send me a link to the exact one that would be even better! The coding on the cap is this in order from top to bottom: F395, 560, 2.5V
    It seems the cap is surface mounted and is about 6mm tall with a diameter of 5mm with a lead separation of 2.5 mm. Thanks you guys so much! I wouldn't ask if I haven't been researching for the past week.
    • 31049
    Re: Identifying Capacitor for my Graphics Card
    560uf 2.5v obviously.
    and almost certanily a polymer cap.
    next time you post a foto, dont use a gameboy camera!!!
    • FlyingMammalMan
      • Nov 2014
      • 7
      Haha I didn't use a game boy cam! It was from an iPhone 5S, I guess only a thumbnail got uploaded?
      Question, should I ignore the F395 on the top? I can attach a higher quality pic if you want. The cap is Surface mounted too.
      Thanks again!
        • 31049
        a better foto may help others ID the make & series.
        • FlyingMammalMan
          • Nov 2014
          • 7
          You're right. Here's a way better pic.
          • selldoor
            Slow Learner
            • 7870
            This might do?
            http://www.digikey.com/product-detai...9CT-ND/4204336
            But you really need the land size and diameter for a smd cap not the lead spacing as that does not figure. ( unless of course you are going to try surface mounting a through hole one?)
              • 31049
              if you look at the space on the board, it looks like it may be drilled for both types - maybe.
              • FlyingMammalMan
                • Nov 2014
                • 7
                No it's not both surface and through hole, I wont attenmpt to mount a through hole one in a surface mount. How do I measure the land size? In fact what is the land size?
                Will this do too? http://www.mouser.com/ProductDetail/...qtMK41m06qA%3d
                I would prefer buying from these guys since they're local.
                Thanks for all your help so far!
                • selldoor
                  Slow Learner
                  • 7870
                  Land size is the size of the base. (mentions it on digikey site)
                  You need to measure the base and check the data sheet.
                  The one you link to according to the data sheet is F61 so is 6.6x6.6
                  the connectors appear to be 1.9 apart so perhaps yours is a larger one??
                  • FlyingMammalMan
                    • Nov 2014
                    • 7
                    Hey guys, I went ahead and ordered the caps from the link from Mouser.com. They turned out to be exactly what I needed; the land size, height, and diameter were a perfect match.
                    Just one thing, the topmost numbers are different; on the original one the numbers is F395, while on the new ones, the number is K28J. Should I be worried? What does that number mean anyway?
                    Thanks for everything guys.
                    • CapSwapper
                      • Feb 2014
                      • 69
                      only thing matters is the capacitance and voltage in that application. It's Chemicon so its a good cap
                      • Fast Alpha
                        • Feb 2013
                        • 245
                        • United Kingdom
                        What soldiering iron do you use.
                        In the Uk they only sell cheap stuff.
                        http://www.hse.gov.uk/pubns/indg305.pdf
                          That cap is part of the switching power supply (see those inductors next to the caps?) filter cap, do not use just any cap.
                          The one FlyingMammalMan selected is the correct type low ESR/Impedance type not general purpose type.
                            • 31049
                            that's not true, look at farnell or rapid and they have very expensive irons.
                            • Fast Alpha
                              • Feb 2013
                              • 245
                              • United Kingdom
                              Which one do you use stj.
                                • 31049
                                a cheap one, i make up for it with customised bits and skill.
                                i got it for £30 including an £18 reel of good solder, and a brass-wool tip cleaner worth £8 in a sale!!!!
                                btw, it splits apart, i put the iron holder section in the bin - it was shit.
                                • Fast Alpha
                                  • Feb 2013
                                  • 245
                                  • United Kingdom
                                  See in the UK they sell cheap crap, but everywhere else they sell good quality.
                                  It's rip off Britain.
                                    • 31049
                                    no, i could have spend hundreds on a pace or Ersa etc, i just didnt want to.
                                    what you dont see in the u.k. is japanese stuff like Hakko or Goot.
                                    • Fast Alpha
                                      • Feb 2013
                                      • 245
                                      • United Kingdom
                                      Even cheap stuff in U.S.A are good enough to desolder caps, but in the UK a 30w or even a 60w can't do it.
                                      What is the best to do it properly being sold now ?
                                        • 31049
                                        you would be surprised how cheap you can go if the tip is big enough.
                                        but if you have hot-air it heps to heat the bottom of the board first.
                                          Lenovo ThinkPad P53 Mobile workstation P Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad P53 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P53 boardview and P53 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 09:53 AM
                                          Lenovo ThinkPad P73 Mobile workstation P Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad P73 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P73 boardview and P73 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                          09-06-2024, 09:45 AM
