Interview with Alvin Chan from Antec
  • TELVM
    • Oct 2012
    • 547
    • Spain
    KitGuru - Exclusive interview with Alvin Chan from Antec
    The guy has this to say about caps (attention: breaking news ahead ):
    KG: PSU vendors often emphasise the usage of Japanese capacitors – what makes these better than others?
    AC: Japan is the leading nation for capacitor manufacturing and material technology. In addition, Japan makes the best aluminum foil in the world, but refuses to sell that foil to Taiwan or China. The reason is simple, because Japan wants to protect its own industry.
    At the same time, the quality of Japanese capacitor manufacturers is unmatched, because they are very strict when it comes to ensuring specifications are matched. You can always trust that they will deliver. In order of quality, the capacitors call into these groups: Tantalum > Solid > Japanese Electrolytic > Taiwanese Electrolytic >>>>> Chinese Electrolytic.
    I didn't know about the aluminium foil touch, interesting.
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: Interview with Alvin Chan from Antec
    Yes. The aluminum foil mined in China and Taiwan is below the minimum purity stated by DAPO (97.5% versus the 99.1% from Japanese foil... might seem like a small difference but it isn't), in accordance with this study:
    However, I believe, as the study concluded, that there is something more to it, besides the fact that the electrolyte has a negative chemical reaction to the poor raw materials as evidenced possibly by the presence of aluminum in the electrolyte from the bulged Taiwanese capacitors in the study in question. Some capacitors have such unstable formulas that they will eventually vent right on the shelf; all it takes is time. This has been observed with NCC KZGs and KZJs (problem seems to be worse without a voltage being applied to them in order to restore or thicken the oxide layer and when heat is involved as well as humidity). The formula probably has to be designed in such a way so as to achieve the lower ESR and good performance needed for motherboard VRM output circuits. Seeing as how lytics don't exist in grades superior to HZ/MFZ ESR wise (both of which were discontinued years ago), I think lytics are simply being pushed too far in that respect, which is why polymers are the future. I wouldn't be surprised if the bad manufacturers don't get their formulas right either (some OSTs and 8mm Teapos have been observed to fail right on the shelf).
    • retiredcaps
      • Apr 2010
      • 9271
      I'm not much of a PSU person, mainly because I use and fix dead ones and tend to use whatever is handy at the moment even in my main systems, but I found this interesting ...
      " That's a huge advantage and really helped us deliver annual revenues over $200 million. Right now, our products are hand-assembled"
      Running a $200 million business with reputation on the line with hand assembly process.
      PS. The used and fixed ones in my systems would make the regulars here cringe at what I'm running sometimes with original factory installed capacitors.
      --- begin sig file ---
      --- end sig file ---
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Stanley1843
        HP EliteBook 2540P - Aluminum Foil on Speakers
        by Stanley1843
        I have the HP EliteBook 2540P and when I disassembly the screen I cut accidentally one aluminum foil where it was on the top of the one speaker. What is the purpose of these aluminum foils on the top of the speakers....
        09-07-2025, 02:54 PM
      • sirpsychol
        Antec Earthwatts EA-380 smd element type/value
        by sirpsychol
        While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
        09-03-2023, 07:58 PM
      • ajdrenter
        Picking caps for Antec SU-380
        by ajdrenter
        In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
        https://www.badcaps.net/forum/showthread.php?t=14159
        It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
        05-13-2023, 10:40 AM
      • CWEastwood
        Antec Smart Power SL300S capacitor replacement.
        by CWEastwood
        I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
        The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
        I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
        Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
        03-25-2023, 12:18 PM
