What do real rubycon yk look like ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hello everyone lately I have notice a very common issue that I have been coming across with rubycon yk series I ordered supposedly "genuine" from a few different sites to get the values I needed but all seem to be of the same quality and I don't feel that they are genuine. The print is ok but not rubycon standard and the bung isn't the usual rubycon type, they measure fine on the esr meter but I would like to know what you badcappers think as I don't want to use these until I can be sure of them.
    Also I have looked these up on-line and they all seem to be the same so I don't know what to think.
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Re: What do real rubycon yk look like ?
    Pretty sure they are fake... The bung should have a dot in the middle, and printing looks bad.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Hello thank you for the reply, I know that the bung looks fake but its the same on all rubycon yks ?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Confirmed these are fake junk.
        • chozo4
          Nothing Special
          • 134
          I have a bunch of YK's I had salvaged off an old plasma TV board long ago. The 16v capacitors I have definitely don't have that dot in the center of the bung but it otherwise matches. I do agree though.. the sleeve printing looks really shoddy in the fakes. The Y and K are spaced too close together and the F in uF is too tall as it's normally about 1/2 the height of the capacitance value.
          Even crap caps can be useful... such as blank rounds for prop gunfights.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I Have confirmed that they are fake they capacitance is correct but esr is too high for that series, put them in the bad cap bag.
              • 31316
              your in the U.K. you have no excuse not to get your ruby/pana/ncc caps from Farnell.
              • mockingbird
                • Dec 2008
                • 5488
                All "Rubycon" from China on eBay are fake.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  I do use farnell but I can obtain genuine capacitors off ebay I only use supplyers like PCMCS BEHMOT when I do use ebay, but these specific caps I brought off ebay ages ago when I wasnt aware of fakes luckily I never used them !
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    True.
                    • chozo4
                      Nothing Special
                      • 134
                      True.
                      Not all are but the chance of them being so are rather high. I ended up buying some Rubycon YXA 400v/6.8uf caps from there that were legit as I needed them in a hurry to fix an SMPS wall wart for my router I was bringing with me overseas. This was before I'd used mouser or newark however.
                      • cnti
                        Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
                        by cnti
                        Hi.
                        BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
                        This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
                        BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
                        RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
                        burned, measured 10M ohm.
                        QM801 [real PSU:...
                        10-19-2023, 05:33 PM
                      • edugimeno
                        Diagnose real-vintage Strong-Hammer arcade machine
                        by edugimeno
                        Hi there!
                        My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
                        I am attaching several pictures of the machine.
                        It basically has 2 sides, left side has
                        • 2 x 220->12+24v transformers
                        • 2 relays (1 moves motor UP, other moves motor DOWN)
                        • IGF and breakers for safety
                        Right side is shown on pictures. It has 3 boards ( top-down)
                        • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
                        02-29-2024, 11:05 AM
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • DynaxSC
                        by DynaxSC
                        06-14-2024, 03:49 PM
                      • Galraedia
                        Fake Caps in Xbox 360
                        by Galraedia
                        I decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
                        02-04-2023, 09:55 PM
