Sanyo DP42848 clicks on and off every 2 seconds
    Hi, my tv continuously cycles on and off every couple seconds. The green light comes with a click, then goes off with a click and repeats.
    My power supply board is only reading 3 volts at the 5v standby terminal, only 10v at the 12v terminal and 22v at the 24v terminal. I do not see any obviously bad caps (none bulging or leaking), but obviously something is wrong.
    I am posting a picture of the board, if anyone could give me guidance on which caps might be the problem, I would greatly appreciate it.
    Re: Sanyo DP42848 clicks on and off every 2 seconds
    blown caps may be the issue. look for a raised surface on any of them. need to post a clearer image
      check these caps and look around for others
        Identifying the capictors is not my problem. I am hoping that someone with a schematic or experience might be able to guide me to the specific caps that might be causing me issue. There are not any of them that appear bulging. I have looked at each one and can't detect any abnormalities.
