Diagnosing short to ground issue
  • Leefreeman97
    • Sep 2025
    • 8
    • United kingdom
    Hello, I have a pcb from an e scooter which had a faulty diode but even after removing it from circuit, it still has a short to ground on the three components circled. I have removed every cap on the board and tested one by one and the short is still there and all the caps test ok. Could this be because I haven’t put a diode back on it yet or where do I go next please?
  • petehall347
    • Jan 2015
    • 4431
    • United Kingdom
    check the regulator
    • khalillll
      • Sep 2025
      • 6
      • &00
      Before that, disconnect any cables connected to the board.
      Inject the low voltage and see which component is getting hot
      • Leefreeman97
        • Sep 2025
        • 8
        • United kingdom
        Which one is the regulator please?
        • Leefreeman97
          • Sep 2025
          • 8
          • United kingdom
          Also, when injecting voltage where would I put the positive wire in the picture please?
            • 31154
            kia117 is a regulator, so is the 6pin chip
            • Leefreeman97
              • Sep 2025
              • 8
              • United kingdom
              How can I check it and in what mode on the multimeter please
              • pcardoso73
                iMac power supply short-circuit diode to ground
                by pcardoso73
                I have an iMac with the power supply reference: ADP-200DFB.
                This power supply is not working and when trying to debug the problem with a multimeter, I found what I thought to be a short circuited diode (the short-circuit is to ground).
                With the continuity test it beeps both ways, so doesn't block current flow at all then reverse biased. But after removing the diode the beep continues and the diode seems healthy. It seems to exist a real short-circuit.
                As I have another ADP-200DFB power supply (faulty one as well), I have checked the same...
                06-09-2020, 08:47 AM
              • duwane
                MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                by duwane
                Hi All.
                I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                10-17-2023, 07:48 PM
              • MakNCheese
                ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
                by MakNCheese
                I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
                Symptoms:
                • Severe lag across the system, including BIOS navigation.
                • Slow boot times and unresponsive performance in Windows.
                • Battery charges very slowly (e.g., ~5% in 2–3 hours).
                • No error messages or BSODs, just extreme sluggishness.
                What I've Tried:
                • Replaced
                06-04-2025, 12:48 AM
              • code share
                Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                by code share
                I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                Here's what I've tried so far:
                • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                • Booted successfully on AC power only with the battery disconnected
                • Visual inspection of the battery — no swelling, burn marks, or connector damage
                • Battery
                04-21-2025, 12:50 PM
              • Cemal Odabasioglu
                MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                by Cemal Odabasioglu
                I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                Observations...
                01-14-2025, 03:54 PM
