Capacitor Outside Sheathing
  • Logistics
    • Apr 2007
    • 721
    So last night I decided to see what was under the outside sheathing of a capacitor; wow, it's bare metal underneath.
    Is there any benefit, such as cooling, to removing the sheathing and leaving it bare metal, such as removing the sheathing from the caps in a PSU for enhanced cooling?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Capacitor Outside Sheathing
    is for cosmetic reasons
    **cough**
    • Krankshaft
      • Jan 2007
      • 2328
      Besides if you removed the sheathing if you ever needed to replace it you would have no idea what its value or working voltage was.
      • Logistics
        • Apr 2007
        • 721
        It would be very difficult to remove the sheathing while it was soldered down. Likely, this would be in a scenario wherein I replaced them so I know what they are. But if there's no cooling benefit, forget it. I just figured that the cooler they were, the closer to spec they would be.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          best to concentrate on case cooling instead
          • Logistics
            • Apr 2007
            • 721
            Since willawake is such a huge help in these dillemae of mine, I am motivated to remove the outer sheathing from all my capacitors, henceforth, for the purpose of sanding and polishing their sweet, aluminum outsides to a beautiful mirrory goodness. And we all know that polished surfaces reflect heat so I should defenitely... oh wait, I said this wasn't for cooling... it isn't, IT ISN'T!
            • Tom41
              • Oct 2005
              • 336
              • England
              Like others said, it's purely cosmetic and a convenient place to put the brand name, capacitance/voltage rating, and negative indicator band.
              Some caps DON'T have an outer sheath and are just metal cans. These usually have the information printed on the top, over the vent.
              You know there's something wrong when you open your PC and it has vented Rubycons...
              • starfury1
                • May 2006
                • 1256
                So I guess cause the layer is plastic
                it may have a little insulation type properties as opposed to a bear Al can
                but as the saying goes it would be a "pee in the ocean" from a heat/cooling perspective
                A fan would be a lot less work and achieve more me thinks
                While looking into caps awhile back I did find some info on the thermal transfer of cap design (area etc of can)...stuffed if I know were the link is now thought.
                Save the spit and polish use a fan
                for that matter
                "Save the Cheerleader Save the world"
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  • USA, Unsure of Planet
                  IIRC, Rifa has a series of large can caps that has a hole down the center to improve cooling.
                  PeteS in CA
                  • MORETTIGIAN
                    by MORETTIGIAN
                    Title:
                    Description:
                    Procedure performed:
                    - Removed backplate
                    - Reapplied thermal compound
                    - Reassembled card
                    09-18-2025, 12:14 PM
                  • Prolog
                    by Prolog
                    12-01-2024, 08:27 PM
                  • Ace Perception
                    Samsung R530 Bremen motherboard cooling
                    by Ace Perception
                    I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
                    I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
                    So I went in pursuit of...
                    07-21-2020, 03:05 PM
                  • chth96
                    by chth96
                    12-22-2023, 04:34 AM
                  • chth96
                    by chth96
                    06-02-2024, 07:31 PM
