Capacitor voltage leak??
  • MagicSmoke
    • Feb 2011
    • 275
    While in circuit and powered on should a capacitor ever have voltage to the metal can that contains it??
    I have 2 220uf 25v caps on an X main board that have 60v when probe is touched to the X vent. None of the others of that voltage and uf have any volts to can.
    Are they bad?? Neither one is bulging. Thanks.
  • mariushm
    • May 2011
    • 3799
    Re: Capacitor voltage leak??
    The voltage written on the case of a capacitor is the maximum voltage the capacitor can tolerate before it becomes damaged.
    The metal case of the capacitor can sometimes be isolated from the capacitor, but it's often "connected" to the negative lead (not on purpose, just a consequence of how a capacitor is built).
    Therefore, it's best to measure the voltage between the two leads of the capacitor, not between one lead and its case, or one lead and the metal chassis.
    I suspect you measured 60v incorrectly, because of different grounds (maybe you put the probe on chassis or the monitor).
    You can't really tell that a capacitor is bad or not by measuring voltage. Even measuring capacitance is not a good way to check a capacitor - it's quite possible to measure the capacitance with a multimeter and see the expected value but the capacitor can still be bad when you actually power up the circuit.
    Proper measurements can be done using LCR meters or ESR meters with the capacitor removed from circuit.
    • MagicSmoke
      • Feb 2011
      • 275
      I did have ground probe on chassis, readings of 60v to can are not incorrect, these are on an X main plasma board which is grounded to chassis.
      3 others of same V and uf have no volts to can. Nor do any of the other cap's on this board (2 100v 220uf and 5 250v 150uf) caps.
      That's why I was curious about reading.
      Board is supposed to be outputting 58v DC and -198v DC its input voltage is 211v DC.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • chth96
        desoldered capacitor is self charging until 0.6 voltage.
        by chth96
        I have an 21 inch CRT TV which is not able to power on.
        I disassembled 21 inch CRT TV and measured voltage of main filter capacitor(Samhwa HC 400WV 220uF) in the circuit.
        It shows 270V on my DMM.
        So I discharged this main filter capactior completely and detached circuit board from cathode-ray tube.
        Then I desoldered this main filter capacitor from circuit board.
        But I noticed that this desoldered large capacitor(Samhwa HC 400WV 220uF) is slowly charged by itself until it reached 0.6V
        I measured its ESR value with MESR-100 and it shows 0.1 ohm,judging...
        03-28-2024, 08:56 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Sparklingx
        SMD ceramic capacitor capacitance & voltage
        by Sparklingx
        what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
        09-12-2024, 01:04 AM
