What preparing should i have for repairing motherboard ?
  • wan901
    • Jun 2007
    • 69
    Guys i like to ask something about this .... what is the thing should i have for repairing ....(soldering , etc....)
  • starfury1
    • May 2006
    • 1256
    Re: What preparing should i have for repairing motherboard ?
    Not quite sure if this is really the right place to be asking the question
    Its more the forum for people to post "Answers and Guides to FAQ's"
    But since you did
    willawake has done an Excellent post as a "sticky" on this
    at the top
    The Recapping FAQ
    Thank you Willawake
    If you are totally new to it the most important thing is to practice on junk pcb's to
    gain experience I think
    Tools and stuff
    (details see the FAQ)
    Antistatic wrist strap and work mat
    soldering Iron
    solder 60/40 (depends), (some flux) and flux remover
    nippy cutters
    Desolder wick, sucker
    Stainless steel needles or dental pick for the hole clearing method
    Mag glass, jewelers loupe
    Some basic electronics knowledge and component ID helps
    Read the FAQ's posts and practice
    HTH
    Cheers
    • glovecaps
      by glovecaps
      11-25-2024, 04:23 PM
    • Docus
      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
      by Docus
      Hi everyone 😀,
      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
      Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
      1. I already own the exact same model, but its plastic chassis is badly damaged.
      06-10-2025, 04:24 PM
    • Archimedes
      HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
      by Archimedes
      Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
      Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
      Fans are spinning. Blindly could install windows11 and got the device manager...
      07-30-2024, 05:14 PM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
      ASUS P5GC-MX motherboard recap
      by momaka
      Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
      This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
      So here is what the motherboard looked like with its original caps:
      CPU VRM area up close…...
      01-27-2021, 11:59 PM
