50's Sanyo monitor
  • m4a2t0t
    • Mar 2013
    • 279
    50's Sanyo monitor
    What type of caps can I use to replace these Rubycon (K) caps? Can I use a film cap? I cant find any aluminum electrolytic caps that go that low. They are .033 uf and .047 uf
    • 31256
    film caps are the way to go.
    • PeteS in CA
      • Aug 2005
      • 3582
      • USA, Unsure of Planet
      BTW, the "(K)" may mean 10% tolerance.
      PeteS in CA
      • m4a2t0t
        • Mar 2013
        • 279
          by momaka
          03-15-2023, 10:17 PM
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
        • keepread
          Dell monitor PSU vs Dell laptop PSU
          by keepread
          Hi there!
          Someone gave me their old monitor, it's Dell S2715ht.
          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
          10-30-2025, 04:45 PM
        • 13mh13
          Aluminum SMD caps vs thru hole caps (reliability)
          by 13mh13
          The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
          https://i.postimg.cc/kGrR6BpZ/image.jpg
          I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
          I have not tested/replaced those alum. SMD electro PCB caps.
          Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
          All the thru hole electros I removed / replaced on this CDP (and most...
          04-05-2024, 07:41 PM
        • wattage
          AOC AG493UCX 49-inch monitor - Firmware request
          by wattage
          Hello Badcaps Community,
          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
          07-13-2025, 04:41 PM
