Epoxy Buger Caps
  • JASTECH
    • Jul 2014
    • 27
    • U.S.A.
    Re: Epoxy Buger Caps
    stj, Thanks, guess I'll test all these from PCB and try to replace what is bad.
    Question, How do you guys store your cap/resistor's? I've used plastic craft containers, seen 3-ring binders used for resistors.
      • 31055
      my caps are in racking - i have a lot!!!
      resistors i get in 50's and are just in ziplock bags
      • JASTECH
        • Jul 2014
        • 27
        • U.S.A.
        stj, can you post pics for me, I need to organize.
          • 31055
          nope, it just looks like a shitload of plastic trays on the wall.
          like these:
          • JASTECH
            • Jul 2014
            • 27
            • U.S.A.
            OK, I thought you had retina scan just to get into your shack, lol.
            I hate the scraping sound of them hard plastic drawers, maybe better units are available nowadays?
              • 31055
              mine are actually plastic-frame, and coloured soft-plastic drawers with a cut-down front edge so you can see the content.
              i had the metal ones and they pissed me off.
              • JASTECH
                • Jul 2014
                • 27
                • U.S.A.
                #27
                Exactly, them metal frames and hard plastic drawers sounded like chalkboards being scraped, then drawers would crack if I looked at them wrong!
                  • 31055
                  this is more like mine.
                  the only difference is mine slide into a rack and these drop onto a wall-bar i think.
                  http://www.harborfreight.com/30-Bin-...ack-69571.html
                  • JASTECH
                    • Jul 2014
                    • 27
                    • U.S.A.
                    #29
                    Update: Removed PCB after unplugging the spegatti life support. The covering that is sprayed onto parts & PCB is making me choke a bit (even on O²). I have never dealt with spray coatings, been setting station temp at 350° and using sucker. I don't like to heat up PCB or parts but it takes a bit of time to get old solder to melt with spray coat. Should I increase temp? Please advise, still young enough to learn. Here is today's pic, will I need to remove all the ceramic bypass caps for ID sense numbers didn't match brands or can you guess the smaller one? Anything else you see I should replace while its out?
                    Thanks, JASTECH
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
