New to recapping (and thanks)
  • comprehensive_computing
    • Jun 2007
    • 14
    Hey I just wanted to thank you for setting up this web site. I'm still green when it comes to recapping, however I'm experienced with soldering and so forth as I regularly replace defective power jacks on laptops. Until this week, I hadn't really put much thought into recapping a board.
    I had an HP desktop which would shut down when I tried to reinstall XP. I did all the routine things a person would suspect with this problem: check memory, try a new processor, check the heatsink, fan and thermal paste, try a different power supply, hard drive and remove PCI cards. I even flashed the BIOS. After running across this site I decided to spend 11 bucks on some capacitors (got the Rubycons of course) and that computer is good as new now. The originals showed absolutely no physical sign of being bad, but I understand they don't always bulge or leak when this happens. Too bad I already pulled out half my hair trying to figure this one out...haha
    Thanks to this site I've caught on to something that could save my customers some serious money (and of course make some myself). I appreciate the open discussion as well. Thanks, guys!
    Comprehensive Computing
    http://comprehensivecomputing.net
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: New to recapping (and thanks)
    The brand(s) of caps?? Replacing power jacks on laptops could practically be a career.
    PeteS in CA
      • Jun 2007
      • 14
      I'm still new to identifying them, but I think the ones I removed looked like Teapos, so I understand that was the problem in the first place. Perhaps that is why they didn't show any obvious signs of problems?
      As for the power jacks, yes, I get a bunch of laptops shipped to me every week to perform that repair.
      • bgavin
        • Jan 2007
        • 1355
        Where do you buy replacement jacks?
          • Jun 2007
          • 14
          The more common ones I get from Mouser and places like that. Some of the others, like the ones used in Sonys, I get from the usual places you find on the net that sell them.
          • tazwegion
            • Jun 2006
            • 444
            Welcome to the forums & congratulations on your first recap project!
            Viva LA Retro!
              • Jun 2007
              • 14
              Thanks, tazewgion!
              • proxneo
                Recapping Sony ICF-SW55 - verifying cap values
                by proxneo
                Dear reader
                I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                At the moment, I have selected replacements based on the following list of values:
                3 x 470uF 10VDC
                3 x 4.7uF 35VDC
                4 x 47uF 50VDC
                8 x 22uF 6.3 VDC
                1 x 220uF 6.3VDC
                5 x 100uF 6.3VDC
                Which...
                06-21-2023, 12:38 AM
              • Green Probe
                Recapping a Denon AVR X6400h SMPS
                by Green Probe
                (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                Disclaimer: I'm an amateur hobbyist and will get things wrong.
                Always use caution when working around mains power and high voltage capacitors!
                Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                SYMPTOMS:
                -No display...
                07-18-2025, 03:36 PM
              • slerner
                Recapping KRK VXT6 without original datasheets
                by slerner
                I'm desperate to save my pair of 2007 KRK VXT6 studio monitors, one of which died.
                Hoping for an easy fix, I bought a pair of new-old-stock replacement main boards. I installed one & it was DOA. Tried the other, also DOA. I suspect that 15 years in a Maltese warehouse dried out the electrolytic caps. I tried replacing just the two largest caps, which didn't help. Except to confirm that the old ones wouldn't reach infinite resistance & were a gram underweight.
                Q: How do I match the caps, since there's no series marked on the originals and no circa-2007 catalog or datasheets...
                01-31-2023, 02:21 AM
              • abajor
                A2141 No audio on speakers, yes audio on headphone jacks.
                by abajor
                I just can't escape Apples most CURSED laptop the dreaded A2141.
                Can't find any info on this speaker problem. I've been digging through the schematics and found there's a separate chip U6300 to drive the headphone jack.
                It appears all of the audio signal is transmitted using i2S. It's pretty wild that the internal speakers have 3 amplifiers each. I'm assuming whatever provides the clock or routes the signal to the speaker amps has an issue?
                U3900 is as far as I've gotten in my exploration.
                Anybody know this issue? Is it fixable? U3900 looks like something...
                12-30-2024, 07:42 PM
                Delta DPS-300AB-24b 300 Watt ATX PSU recapping
                by momaka
                Figured I’d separate the recapping details of this PSU in a different thread so that the information can be easier to find. To be more specific, this thread is about recapping of the Delta DPS-300AB-24b, shown here. All details about the build quality of that PSU are posted there.
                Here is the PSU, just to see what we are dealing with:
                And here is a cap diagram:
                Let’s break it down what goes where…
                * 5VSB
                *** cap spot C952: Ltec LZG, 10V, 2200 uF, 10x30 mm before PI coil
                *** cap spot C953: Taicon PW, 10V, 680 uF,...
                04-24-2020, 07:31 PM
