Used a slightly lower ripple rating for replacement...
  • bw1
    • Sep 2010
    • 172
    Had a Dell Dimension come in that was somewhat urgent. Originals were 8x20mm 6.3v 1800uF 12ohm/2350mA.
    I had matching replacements on hand except the ripple was 2220mA -- I'd like to think that they don't push tolerances quite that far so as to make ~100mA be a crucial requirement.
    Is this ok? I did it in the meantime regardless, so I guess what I'm asking is if I should take the time to replace them with a same/higher ripple replacement or leave them as-is.
    It's a 2GB box running Vista, so if they go bad in 3-4 years it's not the end of the world.
    Any recommmendations would be appreciated.
    • 31170
    Re: Used a slightly lower ripple rating for replacement...
    close enough,
    and if it freezes you can blame the o.s.
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      Should be just fine. But running Vista on 2GB? Even if it's a stable designed-for system I'd think it would be S L O W.
      PeteS in CA
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • quickname
        Cyberpower 1500AVR UPS repair
        by quickname
        I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
        I decided to verify that the batteries were...
        11-12-2023, 09:57 AM
      • Bugmanscj
        Audio Linear Power Supply (LPS)
        by Bugmanscj
        Hi: Found this forum fumbling over the net looking for replacement capacitors for a high quality 2uv ripple model Kaia, Core Audio Technology LPS. I bought it used on fleabay and figured I would have to recap and sure enough one of the 22,000uf 35V 105c caps is bulging. These supplies were made briefly around 2014 for MAC Mini audio servers, and were quite costly at the time ($1.7k), you know it's audio... I will use it for a video processor power supply to replace a switched version. I figure it's a low cost attempt to see/hear what difference it might make in my system. Plus I get to learn...
        02-17-2025, 08:50 AM
      • Hylax
        Replacement capacitor options please?
        by Hylax
        Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
        08-09-2024, 11:25 PM
      • samoelec
        Trying to understand how to find best replacement cap for old parts.
        by samoelec
        Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
        Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
        The power supply board is exactly the same from this post so I'll just steal it for now.
        I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
        04-01-2024, 03:39 AM
