I've been looking around for good quality caps and ones that are the correct ratings. I think i've found some, could someone in the know check that i've got it right?
from www.farnell.com goto the australian version of the site.
then look up the numbers
Cat no. 769071 = 1500uF 10V 10mmx23mm
Cat no. 768406 = 1000uF 10V 8mmx20mm
Cat no. 769150 = 1000uF 16V 10mmx20mm
They should be Rubycon Caps with 105 degrees temp rating and ultra low impedance.
Are these good caps? These should be direct replacements for my VP6.
N.B. Sorry about not posting direct links, the website is really nasty.
