Are these caps any good?
  • MorTus
    • Aug 2004
    I've been looking around for good quality caps and ones that are the correct ratings. I think i've found some, could someone in the know check that i've got it right?
    from www.farnell.com goto the australian version of the site.
    then look up the numbers
    Cat no. 769071 = 1500uF 10V 10mmx23mm
    Cat no. 768406 = 1000uF 10V 8mmx20mm
    Cat no. 769150 = 1000uF 16V 10mmx20mm
    They should be Rubycon Caps with 105 degrees temp rating and ultra low impedance.
    Are these good caps? These should be direct replacements for my VP6.
    N.B. Sorry about not posting direct links, the website is really nasty.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Rubycon ZL series. They are used in many motherboards. Also YXG series is used. Should be excellent.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16955
      The Rubycon MBZ series are also one of the best and lowest ESR available.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Features of MBZ Series
        Capacity as high as 1.5 times the ZL Series
        50% lower impedance and ESR than the ZL Series
        Ripple current as high as 1.3 to 1.5 times the ZL Series
        Use : CPU power supply on motherboards
        Service Life : 2,000 hours at 105degC
        MCZ series
        105ºC, Ultra Low ESR
        MCZ series has achieved lower ESR at high frequency from conventional MBZ series by approximately 40%. The series is recommended for VRM for higher speed CPU's.
        interesting. both have shorter life though. 2,000hrs when ZLH (New ZL) and YXH (New YXG) have 5,000 - 10,000 hrs. does the difference really matter for our purposes?
        • gg1978
          • Dec 2004
          • 431
          Generally the larger diameter electrolytic caps have longer service lives. I've got a bunch of Nichicon UPW series caps, which can be "interesting" to fit on a motherboard, especially the 3300's, but i think they're rated for 7K hours.
          • ncdave
            • Oct 2003
            • 33
            service life
            I think that service life does matter. 2000 hours is less than 3 months of continuous running time.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              cap life is measured at 105degC, actual life is longer at lower temperatures like double every 10degC lower.
