Remove capacitor without damaging the board
  • GoodCapacitor
    • Jun 2022
    • WWW
    I have an old Mikrotik board with one bulging capacitor. It still works, but the cap doesn't look healthy.
    I have tried replacing it, however it seems to ignore my soldering iron like it's a toothpick. I do suspect an industrial-strength lead used during manufacturing.
    How do I remove it without damaging the PCB and (more importantly) surrounding components which might be more temperature-sensitive.
  • petehall347
    • Jan 2015
    • 4426
    try adding 60/40 solder
      • 31025
      what soldering iron and tip are you using?
      • ImpossibleRepairs
        • 27
        Im going to take a guess that its a through hole cap;
        I add a small amount of flux at the base of each leg of the cap from the back of the board (not so much the leg); hold the tip of your iron on one leg of the capacitor at a time until the solder melts enough to push that leg through, swapping legs working the cap until its free;
        A good iron makes the world of difference;
        Other people on this forum will likely have better methods, but this works for me 👍
        • Perry Babin
          • Apr 2024
          • 15
          • usa
          ChipQuik?
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • gusto
            How do I remove the chip from the board
            by gusto
            I am new to hot air soldering. I need to remove one chip from the board. I have a hot air solder and I set the temperature to 350°C. I slowly started heating the chip, but the solder didn't melt. I heated it for about 5 minutes, but the solder still wouldn't melt. I increased the temperature to 450˚C and still nothing. After a while, the board started to change color, but the solder still didn't melt.
            Fortunately, I'm testing it on old network switches to see how it works.
            What am I doing wrong?
            I've seen a lot of videos on youtube and everyone got the solder melted and the...
            10-08-2024, 10:55 AM
