Can I replace 15uf capacitor with 22uf?
  • cap__
    • Oct 2023
    • 13
    "If I wanted to replace an old 15uF/400V capacitor with a new one,
    I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Depends on how it's being used. If it's just a smps primary bulk filter cap, usually that would work fine.
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      Electrolytic capacitors typically are +/-20%, a fact that system designers take into account in their designs. So your new 15uF capacitor is within spec.
      PeteS in CA
      • cap__
        • Oct 2023
        • 13
        Good question. Which to use
        Caption
        • redwire
          • 3912
          Capacitor manufacturers are very good at making their parts exactly at the low end, so I find they all measure -19.9% lol. Why give extra?
          For the new part, it depends on how many watts the PSU is. I find chinese use the smallest possible value and so the cap runs hot from ripple current and has a short life, which might be why the 15uF part died. 120VAC 25W with 15uF it gets HOT.
          Also inrush current with a 22uF cap can be high and make quite a spark when you plug in. Does the PSU have an NTC inrush limiter or resistor etc. ? Without it on 240VAC I would expect a crackle.
          • cap__
            • Oct 2023
            • 13
            "To complete this, differences from 14uF to 19.9uF are negligible, especially when there are 2 of them. This concerns a 230V refrigerator board that is 20 years old. Given that the refrigerator runs day and night, it's surprising that the capacitors have lasted 20 years."
            • cap__
              • Oct 2023
              • 13
              I've made it that way.
              It works fine.
              Thank you all for your good advice. Thank you Richard for new video about caps
              • redwire
                • 3912
                I'm confused - you show a fridge board pic with new 22uF primary caps and small electrolytics for the rest. Then a fridge board pic with 15uF primary caps and polymers for the rest.
                Electrolytics are a downgrade, especially if the board is cold.
                Who is Richard? What video? What make/model is the fridge?
                • MORETTIGIAN
                  Capacitor detached from PCB – RTX 2070 Super Founders Edition
                  by MORETTIGIAN
                  Title:
                  Description:
                  During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                  I did not notice it detaching, so I am unsure of its original location on the PCB.
                  Procedure performed:
                  - Removed backplate
                  - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                  - Reapplied thermal compound
                  - Reassembled card
                  Observed behavior after reassembly:
                  - GPU powers on and operates normally under...
                  09-18-2025, 12:14 PM
                • chth96
                  Is it no harm to replace with capacitor without ripple current rating?
                  by chth96
                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                  Rubycon YK DataSheet (b...
                  04-19-2024, 05:19 AM
                • chth96
                  If I replace with inferior capacitor, Is it No harm to other IC components at all?
                  by chth96
                  I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                  Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                  It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                  So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                  I know that these capacitor will not last as long as nichicon capacitor...
                  12-22-2023, 04:34 AM
                • chth96
                  Should I replace polymer capacitor?
                  by chth96
                  a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                  I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                  Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                  Is this ESR value of polymer capacitor correct?...
                  11-18-2022, 04:22 AM
                • expertreader
                  Found a blown capacitor - is it necessary to replace?
                  by expertreader
                  Hi all, Acer Nitro 5 - GH51M LA-K862P Rev 1A motherboard. I went through all the troubleshooting steps but couldnt find a short on any coils. By chance, ended up finding a blown capacitor PCZ49 which is suppose to be 2.2uF. I can see plenty of 2.2uF in the same +5VALW line which will all parallel up anyway - do you guys think it is critical for this cap to be replaced or i can get away without one?...
                  10-15-2025, 04:54 AM
