Zotac GT 240 Leaky capacitor?
  • Valvados
    • Nov 2013
    • 10
    • US
    My GT 240 slowly went out since I bought it a few months ago. Only got about 30 hours of gameplay on it.
    I noticed there is some drops on the under side where the capacitor is and I didn't notice that when I received it used from amazon. Do you think new capacitors will allow me to boot windows with display driver installed? I can no longer boot with display drivers installed tried many different things convinced its the gpu or capacitors on it.
    Plugged into my friends mobo made it work until for 2 boots now not working again. Worked okay in his rig accept for GPU-Z was instant bluescreen or corruption. GPU-Z works now but the thing wont boot with nVIDIA drivers installed. (win7, 8 tested, WinXP showed corruption on booting with driver not sure if XP will even boot been awhile since tested.) 7 and 8 just black screen make a wierd humm sound from the motherboard or gpu not sure which.
    There's several different capacitors on it theyre silver with red writing.
    [4x in a row on card, one is located elsewhere]
    FP
    03Ad
    1 2 2
    2 5
    Is the one that definitely looks like it leaked some of the others may have leaked as well or blew, drops all over the bottom of the card possibly the residue hit the fan and blew all over.
    Other capcitors say
    [3x 2 in 1 spot 1 in another]
    FP
    04Ad
    2 7 1
    1 6
    A post I made earlier today http://forums.anandtech.com/showthread.php?t=2351915
    Should I try putting some capacitors from my EVGA 5900Ultra or do I need specific voltages?
  • selldoor
    Slow Learner
    • 7870
    Re: Zotac GT 240 Leaky capacitor?
    If it is only a few months old and bought from amazon can you not return it under guarantee?
    • Valvados
      • Nov 2013
      • 10
      • US
      I bought it used on amazon from some one, I don't think used items have any sort of warranty.
      Now to late for that I've put a capactior for my evga on it still I think some of the others are bad too.
      I got some pictures ill post up within the hour.
      [/URL]
      [/URL]
      [/URL]
      [/URL]
      [/URL]
      • Valvados
        • Nov 2013
        • 10
        • US
        Is there not some where I can find these capacitors or better ones?
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          The FP are high quality caps not the issue.
          • Valvados
            • Nov 2013
            • 10
            • US
            Is there a way I can get some? Some of mine leaked b/c of the motherboard causing them to leak or age.
            • Valvados
              • Nov 2013
              • 10
              • US
              Hey guys I'm ordering the parts for a motherboard volt mod and droop mod. only 3 bucks so I wanted to order the capacitors for the GPU with it.
              I have some additional info on the graphics card, I am 100% sure the capacitors are to blame at the moment however the reason why they blew was another issue, motherboard setting.
              This computer will not boot into OS until the area around the capacitors are around 70 to 80 *F. The only thing I think would be affect by temperature would be metal or capacitors and the fact that capacitor juice was all over the bottom of the card.
              The rig is actually pretty stable though no crashes currently sometimes stays on for 2 weeks.
              16v or 1.6amp not sure, 271uF, mode name or creation time04Ad
              25v or 2.5amp notsure, 122uF Model name 03Ad
              Is what I could pull out of the numbers above.
              I think I found the capacitor here;
              http://www.digikey.com/product-detai...7-1-ND/2347917
              here's 2 others that are close I guess
              http://www.digikey.com/product-detai...0-2-ND/2790789
              http://www.digikey.com/product-detai...3-3-ND/2294154
              I'll wait to order it. What capacitor should I get 493-3863-3-ND or 493-4680-2-ND?
              The ripple current is hugely different on them.
              • c_hegge
                • Sep 2009
                • 5219
                The last digit is the number of zeros to as to the last two. So, 271 = 270uF and 122 = 1200uF.
                For the 1200uF caps, this is all that digikey has in stock: http://www.digikey.com/product-detai...2-1-ND/3466044. They may be a bit smaller then the originals physically, but will work fine.
                • mariushm
                  • May 2011
                  • 3799
                  One of the numbers is the voltage rating, the other is the capacitance.
                  In the capacitance code, the last number is how many zeroes are at the end.
                  So FP 03Ad 122 25 tells you it's a 12 x 100 = 1200 uF , 25 is probably 2.5v rating . 03Ad is just a batch number, manufacturing date, whatever.
                  FP 04Ad 271 16 tells you it's 27 x 10 = 270uF 16v capacitor.
                  FP is short for Functional Polymer, it's a kind of solid capacitors, which are hard to produce to have high capacitance AND high voltage rating. The higher the voltage rating, the smaller the capacitance.
                  In your last post you say 1.6v but that's not a standard voltage rating, it's almost definitely 16v.
                  Standard voltage ratings are 2.5v , 4v, 6.3v, 10v, 16v, 25v, 35v and so on.
                  Video cards and computer components don't generally have any reason to have capacitors rated for more than 16v because 12v is the largest voltage in PC.
                  Based on your last message, I'm not sure the capacitors are the problem. It could be a mosfet or a diode that's cracked or faulty in some way, or it's poorly soldered in some way, and the heat may expand the part enough to start working after a while.
                  But if you want to replace the capacitors, you can find them on Digikey :
                  270uF 16v : http://www.digikey.com/product-searc...0&pageSize=500
                  1200uF 2.5v : http://www.digikey.com/product-searc...0&pageSize=500
                  I've left 4v rated capacitors there as well, you can use either 2.5v or 4v with no problems.
                  • Valvados
                    • Nov 2013
                    • 10
                    • US
                    Thank you sweet. Those are a bit lower in cost.
                    Do you happen to know if 1.5nF ceramic capacitor on a circuit board is equivalent of 1500pf?
                    http://www.digikey.com/scripts/DkSea...47570184002575
                    1.5nF capacitors were listed for the vdroop mod which brings vcore down when the cpu has a load.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Google is your friend: http://www.electronics2000.co.uk/cal...-converter.php
                      So yes 1500pF is the same as 1.5nF.
                      But regarding vdroop mods, if it's a motherboard with intel cpu, Vdroop is by design and it's calculated to keep the system stable under all conditions (even overclock). Using vdroop mod when overclocking may damage the CPU - it should only be used when the board has no CPU Vcore adjustments in the BIOS settings, to squeeze the last drop of frequency out of that CPU. If your board does have CPU Vcore adjustments in the BIOS, then in most cases a Vdroop mod is not needed. Also remember that C2D processors respond most well to Vtt (also called "FSB Voltage") and Vcore has less effect in obtaining an succesful overclock.
                      So, again, a "Vdroop mod" is seldom required to achieve a stable overclock. I have only done ONE such mod in my entire C2D tinkering adventure, and that was to stabilize a (rather silly) Celeron D overclock @ 4.2GHz. I have never needed such a mod for anything else, and i've run rather silly FSBs on yer average run-of-the-mill LGA775 mobo.
                      A working TV? How boring!
                      • Valvados
                        • Nov 2013
                        • 10
                        • US
                        I spent all day working on the first 20mHz of the board before I realized that the e7400 is at the top end of the motherboards FSB with a locked multiplier so I'm glad I didn't order the parts and thank you everyone for your replies.
                        It was a lga775 board and cpu actually haha. I have liquid cooling on it and it was bugging me not having it OC'd. Oh well it's fine I paid 15 for the processor a year ago and 3- something for the video card and it runs games way better than a PS3 can.
                        • privato89
                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                          by privato89
                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                          Let's begin:
                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                          03-26-2024, 06:37 AM
                        • Prolog
                          RTX 3080 FE Identifying capacitor
                          by Prolog
                          Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                          I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                          I hope these photos make it clear which component I am referring to:
                          (yes, the soldering is a bit botched from removing the blown one, I know)
                          I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                          12-01-2024, 08:27 PM
                        • hinisa
                          Xiaomi router freezes at boot after re-capping
                          by hinisa
                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                          07-08-2023, 05:58 AM
                        • Luke Anders
                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                          by Luke Anders
                          A few details about the laptop itself:
                          Name: Lenovo Legion 5
                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                          BIOS Version: GKCN60WW
                          EC Version: GKEC65WW
                          Serial Number: PF39AQ7Z
                          Board Model: NM-D562 Rev 3.0
                          RAM: 16GB Installed, DDR4 (brand new)
                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                          I bought this laptop recently from eBay as a faulty device....
                          10-12-2024, 05:13 AM
                        • vionescu
                          Zotac 1070 mini blew off a capacitor
                          by vionescu
                          Hi, last night my zotac 1070 mini blew off a capacitor. I've had a look and identified it to be C336 capacitor and maybe the R005 resistor. Does anyone have any idea what kind of replacement capacitor I need to get to fix it or any boardview schematics for the card?...
                          03-19-2022, 01:09 PM
