Need help removing metal plate from bottom of GX270 board
  • Arpajon
    • Oct 2013
    • 14
    I have a bad capacitor in the row behind the CPU. I've removed the heatsink and CPU but can't figure out how to get the metal plate off the bottom of the motherboard so I can reach the place where the bad capacitor's pins go through. Before I destroy something, I thought I'd ask for help. I've searched for a solution, but all the name guesses I've tried for the 'CPU base bracket' have been fruitless.
    Thanks in advance for any help.
    I should add that the one I'm working on has white plastic clips. I just saw one with black metal screws - I think I could figure out how to remove that one... :-)
  • theOracle
    • Nov 2012
    • 163
    Re: Need help removing metal plate from bottom of GX270 board
    this metal plate is glued down and glued down quite well!
    DO NOT try to use a knife, etc. - you will ruin traces on the backside of the board
    the only safe removal method is a heat gun - like this one!
    __________________
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
    • Arpajon
      • Oct 2013
      • 14
      Thanks for that info. It sure looks like removing those white pins would release the plate. In fact, later yesterday I found another one with bad caps that had the black screws holding that plate on - I took them out and it dropped right off.
      • theOracle
        • Nov 2012
        • 163
        many Dell computers had the metal plates glued on, you can tell them by the fact that when you are looking at the board carefully, you are thinking what the heck is holding this plate on, there are no fasteners holding it on, why doesn't it just pop right off with my thumbnail?
        __________________
        the BIG 4
        • Arpajon
          • Oct 2013
          • 14
          Originally posted by theOracle
          ...you are thinking what the heck is holding this plate on?
          That wasn't my thought here. This one has what look like white plastic push pins in each corner that appear to go through the CPU retention mechanism to the bottom of the board and either have pins/tabs you can push together or maybe even unscrew. We had no luck trying that, or by pushing on the bottom of the pin, or by trying to pry them up using their 'head.'
          I've never seen anything like this, so I decided to seek advice before I ruined something.
          • theOracle
            • Nov 2012
            • 163
            on the ones that use glue, the entire metal surface of the plate seems firmly attached to the board, not just the corners
            it's like you could not slide a sheet of paper anywhere under the metal plate, at any point
            so if yours seems only attached at the four corners, then it is probably not the glued type
            __________________
            the BIG 4
            • Arpajon
              • Oct 2013
              • 14
              You can see all the way through the underneath, from side to side. Looking at the bottom, there are four indentions, one in each corner, with the pin sticking through and apparently secured by some type of clip.
              I was hoping this was not a little-used type of securing mechanism so that someone here would recognize the type and let me know how to remove it as simply as possible.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                push the white pins out from the bottom.a small screwdriver will do.
                then pull the retainer off the top.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  What kc8adu said ^
                  The white pins can be a bit of a PITA to remove sometimes, but that's how it's done. If you happen to break any of the white push pins, just substitute some proper sized screws in their place. That's what I did for mine (the first GX270 I tried).
                  You can see the results in this picture (top left corner of the heat sink bracket):
                  https://www.badcaps.net/forum/attach...8&d=1334645782
                  • brethin
                    • Dec 2008
                    • 1907
                    WRONG They are not glued. They use a small white plastic o-ring type gromit that can be spread out and removed from the top and the pins will drop through. There is no glue anywhere on these. If you got one with glue some idiot put it there not Dell.
                    • brethin
                      • Dec 2008
                      • 1907
                      That is because they use a cushion pad (NOT GLUE) between the metal plate and the bottom of the motherboard which over time tends to stick a bit to the board from being heated. IT is NOT Glue! And Dell has NEVER used GLUE of any type for this.
                      • theOracle
                        • Nov 2012
                        • 163
                        if you will go back and reread this thread, I was obviously referring to a different Dell series. - Many Dell LGA 775 MicroATX boards used glued on metal backing plates, for your information!
                        yes, I am afraid they have, for example I am holding in my hand a brand new Dell motherboard p/n RY007 out of a brand new Inspiron 530S and it is glued! - from the Dell factory.
                        So you might want to find out what you are talking about first, before using terms like "never"
                        __________________
                        the BIG 4
                        • AySz88
                          Tinkerer
                          • Jan 2014
                          • 3
                          Adding information into this ancient thread because it seems like the only freaking place on the Internet discussing the removal of the Dell Optiplex GX270 heatsink retention bracket (Plastic piece is P/N 5Y747, metal piece is P/N 2F402). (There you go, Googlebot, hopefully that's enough keywords.)
                          I had to destroy the white plastic push-pins entirely - they were too tight a fit, even after popping up the pins (from the top of the mobo) using a screwdriver. First, with the mobo upside down, I cut the plastic tips, then removed material from the center of the "pin" with a manual hand drill (a very basic one - just a drill bit with a hand grip on it). That gives the pin enough room to deform - eventually some downward force with the same drill allowed me to push the pins through the board.
                          The metal bracket isn't glued on (in this case). There's a plastic insulating film that has some adhesive that sticks it to the mobo, but you can just fold and tape it out of the way while re-capping.
                          I may have missed an easier way to do it, but this is the way I found....
                          [edit] Oh, and you need to replace the push-pin with a screw (or maybe screw and nut). Will update with specifics.
                          • AySz88
                            Tinkerer
                            • Jan 2014
                            • 3
                            Oops, took too long to edit.
                            To re-attach, I used M4-.7 x 10MM screws with (M4-.7) nuts. (Alternatives exist.) Couldn't find a screw that had threads that could grab the plate precisely, and I would guess the tolerances probably vary too much from plate to plate anyway.
                            (You *can* manage to push out the pins from the bottom without drilling - but it requires way more force than I'd be comfortable recommending. Plus, they don't really hold properly if you try to reuse them, probably because of the bit of plastic that you need to cut off to get at the pin.)
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Good info. Thanks for adding it .
                              I still have my GX270 motherboard ever since I last posted here. It is still sitting unused, though.
                              • soulseducer
                                • Oct 2021
                                • Pakistan
                                old post hope u found out solution. just got pc with bad cpu capacitors and faced same issue as urs so stumble upon this thread in search of solution
                                here whay i did. motherboard facing up used screwdriver to pull up those white studs enough to use needle nose pliers anf pull forcely upwards. done without damaging anything
                                hope this help
                                • soulseducer
                                  • Oct 2021
                                  • Pakistan
                                  hope this help
                                  stud should be pulled halfway. pull whole frame once all four done.
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16956
                                    I always punched them out from the back side with a 1/8" drift and a small hammer.
                                    <--- Badcaps.net Founder
                                    Badcaps.net Services:
                                    Motherboard Repair Services
                                    http://folding.stanford.edu/
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                      by momaka
                                      03-15-2023, 10:17 PM
                                    • ntec
                                      Removing led diode from board
                                      by ntec
                                      I'm trying to replace dead led's from my expensive aquarium lights but I am having a hard time removing the led diodes. I've tried using a hot air station at 500 celcius (932 Fahrenheit) but the led won't budge. I tried blasting hot air from both the bottom and top but it won't budge. I don't have a heating plate so is there a better way? As you can see the bottom of the board is all metal....
                                      01-13-2023, 12:07 PM
                                    • acedogblast
                                      by acedogblast
                                      11-02-2024, 05:13 PM
                                    • ygorsan
                                      by ygorsan
                                      🧩 Problem Summary:
                                      • I
                                      07-28-2025, 08:34 AM
