Samxon large can capacitors any good?
  • theOracle
    • Nov 2012
    • 163
    I took apart my Logitech Z-2300 subwoofer computer sound system (perhaps the best computer speakers of all time) and there are two huge 10,000 uF 35V Samxon capacitors - they look fine, but are these any good?
    I am thinking about replacing them with the identical size and spec. Panasonic TS-HA series
    also, there are many purple color 85 degrees Samxon SS series 47uf 25v small caps - any good? (marked U4A and U5A)
    this unit is older, and I want the best sound and best reserve power for deep bass!
    __________________
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
  • Agent24
    I see dead caps
    • Oct 2007
    • 4970
    • New Zealand
    Re: Samxon large can capacitors any good?
    Last thing I heard here was that Samxon are pretty good, but their GF series are rubbish. That's all I know.
    If you don't like the look of 'em, you know what to do
    -David VanHorn
    • mariushm
      • May 2011
      • 3799
      It will make absolutely no difference in sound quality if you replace those large capacitors.
      They work at 100-120 Hz, they're basically smoothing out the voltage after the bridge rectifier and the classic transformer. Actually, I'm not even sure that system uses a normal transformer. Either way, won't affect the sound and shouldn't be susceptible to failure.
      The smaller capacitors... if the system work fine, I wouldn't change them.
      Would the system work better with other capacitors? I personally doubt it. If I were to change them, I would replace them with just normal standard capacitors or "audio" capacitors (but wouldn't go overboard). I mean, I wouldn't look for some Elna Silmic capacitors from 1990 or some stupidity like that, but I may choose to use Nichicon Muse or other of their audio series instead of standard capacitors. The price difference is not that big.
      Some people that repair receivers and amplifiers swear they can notice difference between capacitors (in the actual amplifier section, not the power section) and quite a few I know don't use "low esr" capacitors like Panasonic FM, FR or Nichicon H* ... and I'd agree the chemistry in those may not be suitable for audio.
      Someone I know prefers for example Panasonic FC.. to him, with some receivers it sounds even better than audio grade capacitors.
      See for example these for 47uF 25v:
      http://www.digikey.com/product-detai...179-ND/1965201
      http://www.digikey.com/product-detai...189-ND/1965211
      • theOracle
        • Nov 2012
        • 163
        I restore solid state vintage audio receivers, amplifiers, and other audio electronics from the 1970's sometimes, and the problem is almost always the old capacitors are just dead from old age, what series do you recommend for that? - I never know whether to use low ESR or not, and sometimes the original datasheets are very hard to find for 70's capacitors to see what the old specs were (ESR, etc.)
        when I repair a vacuum tube (valve) amplifier, it seems like the capacitor choices are much easier to make, because so much research has already been done in the tube audio resstoration field.
        __________________
        the BIG 4
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          you got that damn right! the last time i touched solid state i blew an output IC you cant get anymore, not even a deferential one has the same specks!
          Follow the white rabbit.
          • theOracle
            • Nov 2012
            • 163
            one way to avoid this is to replace ALL electrolytic capacitors before even firing up any vintage electronics, and even then, use a variac (auto-transformer) the first time
            __________________
            the BIG 4
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              thats the thing, i did, and i got 24v at the speaker and BANG out goes the IC i wont work on solid state audio anymore
              there's an old saying "when valves are unhappy they blush, when power MOSFETS are unhappy they scatter plastic."
              that weird thing is a rectafire BTW
              • Agent24
                I see dead caps
                • Oct 2007
                • 4970
                • New Zealand
                I don't think there is anything special about them. In Audio use, Low ESR might sound different, that's all. Probably ripple current rating would matter more, in PSU section. You would likely find the information would be in physical databooks if it existed, like those printed for valves.
                Though I'm sure you could find the information on a vintage radio forum etc, or you could contact www.siliconchip.com.au and ask them, they have a vintage radio restoration section in their magazine which has been going for decades, so they probably know what they're doing.
                -David VanHorn
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • totof
                  EU55JS9000T black screen and sound good
                  by totof
                  Hello.
                  I have this issue on my Samsung EU55JS9000T TV.
                  Backlight is good when the one connect box in not connected to the TV and I can launch the TCON screen test with the remote control.
                  But when I connect the one connect box the backlight immediatly turn off, the sound is OK (TNT source).
                  I dont know if the problem is from the one connect box or from the internal motherboard of the TV.
                  I open the one connect box (reference BN96-37087R) and all seems good, simply the Hawk-P CI is very hot after 5 minutes (~65 degres).
                  Is someone have experience...
                  09-25-2023, 03:23 PM
                • totof
                  LG 43UF640V backlight good but black screen and no sound
                  by totof
                  Good morning.
                  I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                  I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                  In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                  HVDD : 7,28...
                  04-13-2024, 11:37 PM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • redoxy
                  NHT SW10 Subwoofer no sound
                  by redoxy
                  Unit was working then one day no sound with the unit humming when the power switch is in the off position. When I move the switch to the Auto or ON position, nothing happens, the humming stops but no sign of life (power LED was off). I opened the amplifier and noticed one of the main power 6800uF capacitors was bulging. I replaced both 6800uF capacitors and also replace the large resistors (R41 and R140) since they looked burned. The humming when power switch is in the off position was still present but the unit will power on now. Tried connecting signal to it but then no sound. When I move the...
                  06-22-2023, 02:01 PM
