Blown caps reverse polarity?
  • JoeyJoe
    • Sep 2012
    • 76
    I build a capacitance meter today that has been working well. It gives the farad reading on a LCD, which is pretty accurate.
    I tested some blown caps on this thing, but it only gives a reading when the negative is connected to the positive and vice versa.
    Why does this happen?
  • JoeyJoe
    • Sep 2012
    • 76
    Re: Blown caps reverse polarity?
    Ignore that, turned out it works both ways
    • odtech
      Asus UX490U laptop blown (caps?) on power board.
      by odtech
      Greetings friends.
      I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
      I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
      Any guidance...
      08-06-2023, 10:29 AM
    • Dev Goose
      Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
      by Dev Goose
      Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
      What Happened
      The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
      12-13-2024, 03:13 AM
    • zlr8r
      HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
      by zlr8r
      Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
      To begin with, this laptop was dead-dead.
      Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
      • am getting white power led
      • 5-long-flashes on CAPS Lock and NUM lock
      • then, fan full speed
      • CPU heats up some (smaller die PCH, does not)
      • always constant black screen no matter what's tried
      • no USB recognition
      • no HDMI output
      this is as far as I can get with it and not sure where to inspect next ?
      I tried...
      03-27-2024, 03:13 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • whc14765
      1070 - Blown SMD caps, short on 12V PCI
      by whc14765
      Hey
      I got a short on 3 pins of the PCI-E gold connector for 12V.
      I see a few caps near the top right (near main power connector) that look blown, one is showing a short across it to GND.
      Unforunately I don't have a schematic or board view for it (EVGA GTX 1070 FTW 8GB).
      Due to the large number of caps there, I think it may just be decoupling.
      Any ideas on figuring out the cap values? There also isn't any reference numbers for the caps on the silkscreen.
      11-23-2022, 06:42 PM
