Average lifespan of a polymer capacitor?
  • KKvantas
    • Sep 2013
    • 17
    • US
    Hi, I was just curious if the brand of solid capacitors mattered as much as it did for electrolytic capacitors and if solid caps last a long time in general if they're used in things like motherboards and graphics cards.
  • mockingbird
    • Dec 2008
    • 5488
    Re: Average lifespan of a polymer capacitor?
    Depends which...
    There are different kinds of polymers... If your thinking about Ultra-Low ESR polymers, there are two varieties, both of which should last well over several thousand hours, one more significantly longer than the other.
    • BillV
      • Sep 2013
      That's not very comforting. There's 8765 hours in a year so it sounds like if you leave it running, you should expect it to fail in about six months. I'd really expect 50,000 hour minimum for a consumer product. Maybe even 100,000 hours.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        remember that the rating is at max rated ripple and temp.
        and they dont just die at the end they just go out of spec.
        only way a pc runs at 105c is if its on fire.or the room its in is.
        and something else will give up before the polys.
        • theOracle
          • Nov 2012
          • 163
          the brand of any cap always matters!
          In solid caps, stick with Rubycon, Panasonic, Nippon Chemi-Con, Fujitsu, and Nichicon
          __________________
          the BIG 4
          ~~~ the top tier of low-ESR electrolytic capacitors ~~~
          • cheapie
            null
            • Jul 2010
            • 849
            Actually, I hear it doesn't even mean that much... I heard that it means "after this many hours, it will still be in spec". It doesn't mean it'll go out of spec right then. It could last twice that, or even more...
            • brethin
              • Dec 2008
              • 1907
              The (reliable and proven specs) for a cap matter more than anything. Just going with a brand can leave you paying more and getting less if you don't know what you are buying. Solid Polymers tend to last longer than electrolytic due to design and being the next generation per say.
              Any cap misused or abused will fail, but for a general standard (used correctly in the circuit) Polys will last longer than Electrolytic only because they are designed to do so.
              • theOracle
                • Nov 2012
                • 163
                Sorry pardner, but that's as silly as saying what brand of car you buy has no effect on reliability!
                but in reality, the brand of car and capacitor you buy has everything to do with reliability and durability!
                There are Lexus's, Hondas, Subarus, Acuras, Toyotas and Infinitis at one extreme if you like to never see your mechanic, and Dodge, Ford, Land Rover, Jaguar and Chrysler's for you folks who like to have your car fixed on a regular basis.
                In the capacitor world, pretty much the same story, just a different set of Japanese names at the top! - and as far "paying more"? - I don't think that 10 cents for the finest low-ESR 10uF 50V cap made is gonna break me, ya see, I've got that kinda cash!
                __________________
                the BIG 4
                • KKvantas
                  • Sep 2013
                  • 17
                  • US
                  i think this is half on topic lol, how long will a motherboard with Taiwanese polys probably last me?
                  • theOracle
                    • Nov 2012
                    • 163
                    if the polys are from a top Taiwan, Japan or Korea cap company, they will last long enough that you will no longer care about the old board by the time they go bad.
                    __________________
                    the BIG 4
                    • KKvantas
                      • Sep 2013
                      • 17
                      • US
                      what would a top Taiwanese brand be?
                      • cheapie
                        null
                        • Jul 2010
                        • 849
                        Teapo?
                        • Rulycat
                          • Apr 2010
                          • 724
                          Taicon?
                          • mariushm
                            • May 2011
                            • 3799
                            Lelon?
                            ( by marketing and sales volume only, not necessarily quality)
                            • Wester547
                              • Nov 2011
                              • 1268
                              • USA.
                              I'd say Samxon minus their GF series.
                              EDIT: That is if we're talking Chinese capacitors, and if not them then Aishi. Taiwan would be Taicon, probably.
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                I thought Samxon was based in china? I guess I would say Taicon
                                • theOracle
                                  • Nov 2012
                                  • 163
                                  I only use Japanese and Korean capacitors.
                                  favorite Korean brand is Samyoung
                                  some other great Japanese electrolytic brands not mentioned in my previous posts are Toshin Kogyo, ELNA, and Hitachi
                                  __________________
                                  the BIG 4
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    I wouldn't consider TK great. Seen a lot of them fail, especially on motherboards
                                    • theOracle
                                      • Nov 2012
                                      • 163
                                      I guess I should clarify, I mean the Japanese made ones, not the relabeled OST crap
                                      __________________
                                      the BIG 4
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        • MORETTIGIAN
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          Procedure performed:
                                          - Removed backplate
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          09-18-2025, 12:14 PM
                                        • chth96
                                          Should I replace polymer capacitor?
                                          by chth96
                                          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                                          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                                          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                                          Is this ESR value of polymer capacitor correct?...
                                          11-18-2022, 04:22 AM
                                        • eccerr0r
                                          solid polymer electrolytic capacitor go boom?
                                          by eccerr0r
                                          Anyone had a solid polymer capacitor fail for whatever reason?
                                          How do they fail? Do they explode, go open, short out, ?
                                          How about for different reasons: forcing excessive ripple current, overheating, voltage too high, reverse voltage?
                                          Just wondering about the causes for a potential shorted solid polymer capacitor... trying to debug a board that has a ~4Ω "short" on a track... it may or may not be a capacitor but was wondering what if it were...
                                          07-25-2022, 07:12 AM
                                        • Prolog
                                          by Prolog
                                          12-01-2024, 08:27 PM
                                        • Agent24
                                          Dick Smith Q-1760 linear power supply filter capacitor question
                                          by Agent24
                                          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                                          It has at least one problem.
                                          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                                          I have already ordered a replacement potentiometer, so that's not an issue.
                                          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                                          All are CapXon...
                                          10-21-2025, 05:39 PM
