Panasonic capacitors at low price
  • Tioleco
    • Apr 2010
    • 46
    • Brazil
    I found Panasonic capacitors at very low prices in a authorized distributor ( Avnet ) , some models appear as excess inventory and other such obsolete, is a good business buy them?
    Perhaps can be very old stock or other problem?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Panasonic capacitors at low price
    i bought a bunch of non rohs parts on clearance from places like that.no problems.
    if they are values/series you use stock up!
      After all of...
      07-13-2024, 08:14 PM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • iMic
      IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
      by iMic
      Hi folks,
      I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
      The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
      11-29-2023, 06:44 AM
    • slybunda
      AA and AAA battery charger capacitors?
      by slybunda
      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
      it has inside:
      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
      2 x 470uf 16v LZ105c branded as G.Luxon
      not heard of these brands are they any good?
      iv attached photos of the charger and the board inside for an idea on the type of...
      12-24-2023, 04:41 AM
