Rubycon MCZ and Chemicon KZG mass failures
Re: Rubycon MCZ and Chemicon KZG mass failures
Agreed. KZJ are just as bad as KZG. I've seen lots and lots of them fail in cool and open environments. Ruby MBZ/MCZ usually only fail in hot SFF Roasting oven PCs (with the exception of a few bad batches).
Disagreed. On motherboards, you can just drop the capacitance back to 820 or 1000uF when polymodding. The lower ESR of the polies means that they can filer more ripple at a lower capacitance than what electrolytic caps can. I've done it several times before.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
A bit of personal background ... I've worked in P/Ss since 1980, except for some 4 years at a motor control company (which is pretty similar in many respects). Ultra-low impedance caps such as Rubycon MBX/MCZ, Nichicon HM/HN or UCC KZG/KZJ weren't what I worked with - 2000 hours rated life (at max rated ripple current and temperature) wasn't appropriate for products expected to last 10 or 20 years (the motor controllers). But Nichicon HE, Panasonic FM, Rubycon ZL and UCC KZE are of that electrolyte type (not quite as low impedance) and are rated for 5000-10000 hours life. So I compared a part in Rubycon's ZL and RX30 series, 3300uF, 10V (the lowest voltage rating available in RX30):
ZL: 12.5mm x 25mm; 18 m-ohm impedance; 2.77A ripple current; 5000 hours;
RX30: 16mm x 25mm; 34 m-ohm impedance; 1.90A ripple current; 4000 hours.
Here is the corresponding data for Nichicon's PW (7000hours) and PA (5000 hours) series parts:
PW: 12.5mm x 25mm; 30 m-ohm impedance; 1.95A ripple current;
PA: 12.5mm x 25mm; 22 m-ohm impedance; 2.28A ripple current
Other than being rated for 130C rather than 105C, Rubycon's RX30 is more similar to Nichicon's low impedance PW series than Rubycon's almost ultra-low impedance ZL series (water-based electrolyte) or Nichicon's almost ultra-low impedance PA series (non-water-based electrolyte).
All that said, the RX30s might do very well for a long time in your mobo if the mobo design has enough margin in ripple tolerance, in its regulator compensation, and in the ripple current to which the caps are subjected (or if the user isn't stressing that area of the mobo to the max). But if is one of the biggest words in the English language.
But in all honesty, the fact that the KZGs were there means RX30s would be an upgrade to the circuit (a poor capacitor series that is practically already dead won't offer any ripple tolerance)... also they are of considerable higher voltage.
The systemboard was running fine until I took it out again for some other changes, but that's my fault.
Yeah KZJ is bad (I was thinking of KZE).Comment
I found a small form factor IBM P4 on the side of the road the other day, and the mainboard and PSU were both thick with dust.
All caps on the mainboard were were Rubycon (MBZ, CE and YK), with the rest being Chemi-con KZGs and polys.
A total of twelve caps had failed on the board - notably, a handful of KZGs, a few tiny Rubycon CEs (with the small [R] logo) which had between 5 and 12 ohms ESR (only one of these was still good, with 1.44 ohms ESR), and three failed YKs, one of which was open circuit. In the mix were three Rubycon MBZs and eight Chemi-con polys, all of which were still good.
Unfortunately I never took any photos of the IBM board and it went in the bin after the caps and useful bits were pulled - in fact, I don't even remember what model the PC was aside from it being a Pentium 4 from 2003 (going by the PSU it may have been an S50). It has a laptop style floppy drive, with a ribbon cable going directly to the board in place of the regular floppy cable, which the board also had.
I never even bothered to power it up with the dead KZGs in there - the hard disk and CD drives were already removed when I found it as well. The CPU was also passively cooled, just to make it even more hotter in there I gather (just perfect for KZGs and general purpose, 85°C caps).
I haven't opened up or tested the PSU yet but there is a crapload more dust in there (surprisingly, the fan isn't seized). The PSU is a 200W AcBel API2PC23, and might make it to the PSU pictorial thread if I get enough time.Comment
In my cap testing (some 5 years ago, now!) I found the water-based electrolytes seemed to expand more than did conventional electrolytes. Among series with water-based electrolytes, some parts did better in my torture test than others (e.g. HE did better than HD, ZL did better than YXG, etc.). I don't have any explanation to offer, just the empirical observation.
In my very abusive testing, HE and ZL are approximately peers, and KZE is close. YXG didn't fare as well. Because I have a hard time getting Rubycon parts (their sales/marketing in the US is execrable, and has been since at least the late 80s), I haven't tested as many of their parts. YXG did do better than PJ, PL, PW, and LXV, however.
Also, those SFF cases don't cool very well, so I'm not surprised there were failed KZGs, MCZs, and 85*C capacitors in the unit Heihachi_73 found, especially with a passively cooled CPU...Comment
by RUllER
This is not a fake Chemicon, it is genuine
Many companies are outsourcing to Chinese factories....-
Channel: General Capacitor Questions & Issues
by rsugaA bit off-topic but I just wanted to share my experience with this power supply. I've owned it for almost 10 years now with moderate usage (daily, but no OC). Had to replace the fan and the OST RLX series caps (the blue ones), which failed on me twice (one cap was bloated, the other one was bad but didn't show visual signs).
I read somewhere in the forum that these blue OSTs were crap, and I can confirm I had two failures. Of course I've been using them for a long time, but still...
I replaced the first one with Nippon Chemicon KY series (the only good ones I could... -
Does anyone have experience with finding Mastervolt schematics?
I have a defective Mass sine 24/1500 inverter that I want to inspect and repair, but without schematic it won't be easy
I've already tried googleing an searching on the FCC site, but without any result.
Thanks for the help!04-19-2023, 05:30 AM -
by bjs59What we have here today is an Intel DG33FB motherboard, circa 2007... I need to replace some of the caps on this board... From what I have found, one of these caps was sort of well known here back in the day as they were used in XBoxes and XBox 360s as well....They are the Rubycon MFZ series, in particular the 6.3 v 3300uf 10mm X 20mm... I have found a seller on Amazon, The Capacitor Store, that has them listed but I have a hard time believing these are genuine pieces... The original recommendation was to replace any bad ones with Nichicon HZ series since the Rubycon MFZ's were a custom product,...
by iMicHi,
Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...-
- Loading...
