MSI 6309, Epox EP-3VBM+ and Chaintech 7AIA5
  • Jazzper
    • Dec 2006
    Hello guys, first post here, hope you can help me.
    I got 3 motherboards on which i spent a lot of time in the past but they seem dead. I'm now in the stadium of recapping or the dustbin for them
    I ran tests with a lot of variables like other memory, different cpu's, coolers, vga cards, pci vs agp, different PSU's etc etc so I converged the problems on those boards due to the mainboards itself. Needless to say i also tried resetting CMOSses etc etc.
    Boys, meet the victims:
    1. MSI 6309
    socket 370 board. I use it with a Piii 800EB. Former owner used a Piii 866.
    Manage to install WinXP actually but after first reboot (post installing, pre first run in gui) it just keeps on rebooting. Frustrating because it doenst seem dead
    Even knoppix won't run. Tried with AGP and PCI cards etc. The caps did it?
    Caps are: Tayeh 2700's (the black ones), Chhi's (1500's, green)
    2. Epox EP-3VBM+
    This nice uATX s370 board came with a Celeron 633. Got it from a friend because it seemed broken. Well it wont give a kick. Fans wont start running.
    Is it really a unit lost?
    Caps brands are Tayeh (the green ones), GSC (the little black ones) and Stone (black)
    3. Chaintech 7AIA5
    Bit the same story as the Epox. Got it for free but never worked. SocketA (462).
    Caps are D.S. 2200's black, NKCon (?) (green, japan), S.G.(?)
    Any clues?
    Don't be fooled by the Canon Powershot lens. The wide angle is kinda having a barrel effect so even a brand new cap will look round barrelled I'm afraid
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: MSI 6309, Epox EP-3VBM+ and Chaintech 7AIA5
    no.1 and no.3 the photos show you definitely have badcaps. no.2 they are all bad brands and are probably failed.
    no.1 you have a very good change of successful recapping (still posts)
    no. 2 and 3 may need more than recapping but its worth a try
    • Jazzper
      • Dec 2006
      hmm thx for the clearifying reply.
      Time to heat up that iron pistol of me
      I will gonna read some topics around here before starting but as a 1st question: do i need to recap all the caps or just the biggies?
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        you should recap all 1000uf and above. if you have any small caps with high voltage like 470uf 16v and 330uf 25v you should do them as well.
        you mention a pistol iron? it may be too powerful
        • Jazzper
          • Dec 2006
          no it was a word joke
          i mean my ordinary Weller 25Watt
          • kotel studios
            Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
            by kotel studios
            Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
            Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
            So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
            What I've tried so far:
            replace the original N-MOSFETs with beefier 60V ones for testing
            Resolder the resistors near the Vcore Jumper block
            Short Vcore...
            05-25-2025, 01:46 AM
          • kotel studios
            Epox EP 8K3A+/8K3A - need specs of 2 caps in DDR1 VRM arena
            by kotel studios
            Is there anybody here who could tell me what are the two caps marked bellow? Or atleast send me a picture of those two caps from their board. Size wise I think those will be 2200uF10v, the same as in the CPU VRM, but not sure....
            01-18-2025, 08:54 AM
          • bauto601
            Chaintech Apogee 7VJL Unstable
            by bauto601
            I'm having a problem with a rather old board, a Chaintech Apogee 7VJL.
            The pc setup is:
            - Athlon XP 3000+ (175x13)
            - 3x 512MB Corsair XMS PRO @350MHz
            - ATI Radeon X1950PRO AGP
            - Chaintech Apogee 7VJL
            - Levicom VP550 (with an acrylic top, is actually fairly decent and recapped
            on the secondary side with Panasonic caps)
            - Club3D Theatron sound card
            - USB 2.0 card with ALi chipset
            - 2x 40GB Seagate HDD's
            - 2x CD/DVD Combo drive
            - 1x Floppy drive
            Now,...
            10-29-2019, 10:05 AM
          • ssl6
            MSI K7T266 Pro (Ver. 1.0)
            by ssl6
            Hey Everyone,
            Long time lurker, but I think this is my first time posting.
            Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
            I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
            11-09-2023, 01:00 PM
          • bigbeark
            EPOX EP-MGF6100-M No USB Sound
            by bigbeark
            This is a Socket AM2 Nvdia board with GeForce 6100 chipset.
            The Onboard sound does not work if I use USB headphones but does work if I use the mini RCA jack. I did use the USB ports on the actual motherboard.
            Made me wonder how USB talks to the audio chip in every other motherboard but not this one. I do find the audio a bit weak. I could replace the small caps near the audio port stack
            but I don't expect it to fix the USB sound.
            Any ideas on how to fix this? I could just add a PCI audio card but it's nice to have front-panel plug in sound.
            02-25-2021, 11:05 PM
