Dell XPS 600 FET's
  • test4echo
    • Apr 2013
    Dell XPS 600 FET's
    I am ordering the typical Dell XPS 600 8 caps, coil and FET's.
    However, i cannot figure out what the proper FETS are.
    The FET are stamped:
    F 1F29Se
    FDD 8870
    Not sure what the specs are on it.
    Is this the part?
    http://www.digikey.ca/product-detail...FSTR-ND/976978
    Anyone know?
    Thanks,
  • delaware74b
    • Apr 2009
    • 628
    Re: Dell XPS 600 FET's
    It is the correct one except that link is for the 2500 count reel.
    Unless you're buying 2500, you might want to check:
    http://www.digikey.ca/product-detail...SCT-ND/3478291
    You can order as few or many as you need.
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      2500!
      • test4echo
        • Apr 2013
        Originally posted by shovenose
        2500!
        Yea dont need 2500! lol,
        Just wanted to be sure of the part.
        Thanks guys,
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
          Dell Thunderbolt Firmware
          by SMDFlea
          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
          The SKU is in brackets (****)
          EDIT: NVM65...
          01-26-2025, 06:22 AM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
