Sanyo Vs RubyCon
    Sanyo Vs RubyCon
    Which caps are better and have long life ?
    Re: Sanyo Vs RubyCon
    They are both excellent quality, either one won't give you any trouble. When buying, make sure you get them from a reputable source, I've heard a lot of horror stories about Sanyo fakes lately.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      nichicon also same quality as sanyo and rubycon ?
        Avoid Nichicon HM and HN series caps, they're prone to failure.
        Team : 49813
        Join in!!
        Team Stats
          Nichicon HM(M)
          avoid ?
            yup, avoid.
            Team : 49813
            Join in!!
            Team Stats
              Just an unrelated curiosity, but Nichicon HD and Nippon Chemi-con KZE have nearly identical specs for most caps, e.g. 1200/16 has an ESR of 22 mohms, ripple current rating of 2150 mA and endurance of 4000 hours.
              They're so close that one could conjecture that they're made in the same factory and badged differently. Between the two, I usually prefer the lacquer-coated bare-aluminium Nichicon HDs because they look cool, but they're not always readily available in useful values - in which case they can be substituted by KZEs of the same value.
                The only KZE's i can get are in 12.5mm.
                If only i can get MBZ, ZL, YZG in 3300uf 10mm i'll be Rubycon fanboy.
                Sanyo offer a complete choice for me (WX, WG). So you can call me Sanyo fanboy
                Though, my favorite by their great spec and longevity (in order) are:
                -Sanyo WG
                -Nichicon HE
                -Chemicon LXZ
                -Chemicon KY
                -Rubycon ZL
                -Rubycon MBZ
                -Panasonic FC
                Others that i dont like, like PW, KZE, YXG, FJ, etc is because their 12,5mm dia. or short longevity. So, all my opinion is very subjective, not scientific measurement, nor i have enough time to do lots of experiments. I would trust opinion from pro's like linuxguru, pete, davmax, gonzo, n others coz they really know what they say.
                days are so short when you actually do something..
                  Thanks for the compliment. BTW, there are some useful values I've used in PW, KZE, YXG and FJ in 10 mm:
                  PW - 1000/10
                  KZE - 1200/16
                  YXG - 1500/10
                  FJ - 1800/16
                  The FJ is very small for 1800/16, so I'm reluctant to use it in a PSU unless nothing else will fit (usually 1U/2U PSUs, or those funky Channel-Wells found in Shuttle SFFs).
                  In addition to your list, I'll also add Rubycon YXF, Chemicon LXA/LXF/LXJ, Nichicon PL/PJ/PM/PS and HD as being excellent (in some cases, older) series.
                    does the Panasonic FJ capacitors are good and better than nichicon HM ?
                      Is it just the HM and HN series you have to watch out for, or are all Nichicon caps prone to failing now? My Athlon 1.2GHz machine (old by today's standards, I know) is full of Nichicon caps, but they're not HM or HN. I think they're HD.
                      You know there's something wrong when you open your PC and it has vented Rubycons...
                        i wouldnt worry about it
                        anyway the best procedure on any machine is do a dust removal periodically and check the caps also and then any other prob like crashing etc asses it immediately and try to determine what is going on whether caps, ram, psu, hdd etc....
                          how about United Chemicon KZG and sanyo SPEC capacitors? My MSI (K8N Diamond Plus) motherboard uses these 2 brand of capacitors.
