MCP61PM-HM - Motherboard Holder..
  • jpreville
    I'm posting this to thank you. For the information and the Service of badcaps.net. This was my first motherboard recap. Done for some elderly folks that i new. That realy didn't need a new machine or board. Was really happy on how fast the caps came in the mail.
    above is a motherboard holder i built out of wood and some rods.. thought someone might be able to use the idea.. helped me keeps things steady while recapping.
    Thanks again
    John
  • c_hegge
    • Sep 2009
    • 5219
    Re: MCP61PM-HM - Motherboard Holder..
    Nice. One other thing I usually do with those motherboards is put a 40mm fan over the chipset heatsink. Because these have nVidia chipsets, which have the underfill defect, they need to stay as cool as possible.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      Nice work! The best part is, that looks like my kit!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • bfordz
        • Aug 2011
        • 81
        Thanks, nice idea. I'm just starting to do mobo recaps; lcd's and psu's, no mobo's yet, parts on order.
          master hoarder
          • May 2008
          • 12175
          Brilliant!
          Definitely going in my projects "to do" list when I have time . Up until this point, I would just hold the motherboard with my body (or rest it on one of my hands) while soldering with the other.
          Thanks for posting this.
          • jpreville
            @Topcat...
            Yup.. your kit! after scouring around at local electronic stores and not finding jack and discovering this website... It worked about perfect.
            Thanks Again
            John
            • glovecaps
              by glovecaps
              11-25-2024, 04:23 PM
            • Docus
              Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
              by Docus
              Hi everyone 😀,
              I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
              To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
              Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
              1. I already own the exact same model, but its plastic chassis is badly damaged.
              06-10-2025, 04:24 PM
            • Archimedes
              HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
              by Archimedes
              Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
              Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
              Fans are spinning. Blindly could install windows11 and got the device manager...
              07-30-2024, 05:14 PM
              ASUS P5GC-MX motherboard recap
              by momaka
              Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
              This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
              So here is what the motherboard looked like with its original caps:
              CPU VRM area up close…...
              01-27-2021, 11:59 PM
            • dragon3x
              by dragon3x
              power on.
              Here are some examples :
              switching supply area).
              than 6.3 V.)
              03-21-2025, 02:46 PM
