Capacitors look ok can they still be bad?
  • dand
    • usa
    I have a Vizio vp322 that has the power problem that seems to be a common topic on-line. I took it to a repair shop that offered free estimates and they said it was a power board that they could replace for $140. Since I inherited this tv and Vizio says it's 5 years old, I started searching for cheaper alternatives.
    Note that when I took the tv in to the shop, I could get the tv to power on after about 2 minutes of pressing the power button and eventually getting the white Vizio logo to stay lit. But after I picked it up from the shop after declining the repair, it won't even go into standby mode with the orange light lit.
    I took the cover off and looked at the capacitors, but didn't see any bulging or leakage that all the photos of bad capacitors on-line use to identify bad parts . But my question is: Can they still be bad or be too weak to power up the tv, even if they don't bulge or leak? If so, I think I'd try to replace them before junking the tv.
    Any help from one of your knowledgeable forum members will be greatly appreciated.
    Thanks.
  • mariushm
    • May 2011
    • 3799
    Re: Capacitors look ok can they still be bad?
    Yes, it's possible.
    Check the voltage regulators on the boards, 1.2v , 2.5v , 3.3v, whatever is there... also check the main power supply...
    • dand
      • usa
      Thanks for the information. Unfortunately, I don't have any electrical tools (or very much electrical knowledge, to be honest. I'm pretty handy otherwise, though.)
      But as long as they can be bad without having any tell-tale visual symptoms, I guess I'll try replacing them.
      • mariushm
        • May 2011
        • 3799
        A digital multimeter is cheap, can be as low as 3-5$, and for measuring DC voltage even such cheap tool is adequate.
        Go grab one and test the voltage regulators. If you don't know which are those, make some clear pictures of the boards inside and we may be able to point them out for you and tell you where/what to measure.
        • dand
          • usa
          Sounds like a good idea. Didn't realize the tool could be that cheap. I'm pretty sure I can figure out how to use it. Thanks for the help. Much appreciated.
          • dragon3x
            by dragon3x
            power on.
            Here are some examples :
            switching supply area).
            than 6.3 V.)
            03-21-2025, 02:46 PM
          • slybunda
            AA and AAA battery charger capacitors?
            by slybunda
            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
            it has inside:
            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
            2 x 470uf 16v LZ105c branded as G.Luxon
            not heard of these brands are they any good?
            iv attached photos of the charger and the board inside for an idea on the type of...
            12-24-2023, 04:41 AM
            After all of...
            07-13-2024, 08:14 PM
          • Cama
            Solar Inverter - SMH-II - 2 missing capacitors
            by Cama
            I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
            My model is : EASUN SMH-II 7 KW
            Mother Board : P/N 18947-002401250250
            Maybe the EASUN SMH-II 4.2 KW have the same capacitors
            Thank you...
            09-12-2025, 02:50 AM
          • Ady2017
            Are there any datasheets available for Elna RJG capacitors?
            by Ady2017
            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
            05-25-2025, 02:19 PM
