Identify Capacitor
  • fleater
    • Dec 2011
    Identify Capacitor
    Hi Guys,
    I am trying to identify a capacitor that has broken on a foot pedal of my welding machine.
    I know that this is mainly a website for computers but is a capacitor not a capacitor?
    Regards,
    Fleater
  • Blargh523
    • Dec 2012
    • 46
    Re: Identify Capacitor
    What's pictured: Cera-Mite (AKA Vishay) part number 565R5HKP10 (now obsolete).
    0.1uf 500V ceramic -20%/+80%
    Replacement Vishay: S104Z93Z5VL83L0R
    Or with a better tolerance range (which is easier to find)
    Vishay: 5GAP10BJA1
    Kemet: C330C104MCR5TA
    AVX: SK537C104MAR
    • fleater
      • Dec 2011
      Thank you very much for your fast response!
      Vishay: 5GAP10BJA1
      AVX: SK537C104MAR
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • SrMrPixel
        need help to identify a failure on DIY guitar pedal (MXR Micro Amp)
        by SrMrPixel
        I'm building this pedal for the second time and it has the same failure. Voltage divider not working as it should. Before the 10M resistor it works, 4.5v, but after it the voltage drops depending on the value of the resistor I put on. 10M=0.45v 2M=1.9V and so on. It should not do that, that resistor is just for biasing the input signal.
        Any idea?
        07-24-2025, 12:42 AM
      • CG2
        Janome DC3050 Sewing Machine Pedal Resistance
        by CG2
        OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
        Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
        04-14-2023, 07:53 AM
      • BlackBurn
        Help to identify a laptop mainboard SMD capacitor LA-9982P
        by BlackBurn
        I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
        Thank You. Stay Safe.
        Chamara...
        11-27-2020, 08:30 AM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
