I'm looking to get an ESR meter and a capacitance tester. I don't want a cheap unreliable one but I also don't want the most expensive one possible. Any one have any suggestions?
Suggestions for Capacitance and ESR meter?
Re: Suggestions for Capacitance and ESR meter?
I have one of these and I´m very happy with it
http://www.home.agilent.com/en/pd-19...?&cc=SE&lc=eng
(although there is one model higher that can go to 100 kHz)
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by DynaxSCHi,
I have this board, where I have exchanged the LGA1151 socket. During testing I discovered, that the large PCIEX16 slot won't by no force work in x16 mode, but keeps to work in x8 mode only.
I tested this with GPU-Z, also with Render Test (but tried also Furmark and Heaven Benchmark - no effect).
Tested on Core i5-9600K as well as on an Pentium G5420 and MSI NVIDIA GTX1070 and 2 other cards, including RTX3060Ti.
Board architecture definitely allows x16 mode, as all 16 PCIe lanes are present between CPU and main GPU slot (nearest to CPU).
...05-04-2025, 12:08 PM -
by jorpecHi
Thnaks -
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer... -
by sam_sam_samAre these ESR capacitor tester any good
https://www.ebay.com/itm/29436085379...cAAOSwavphKIy4
Or this one
https://www.ebay.com/itm/22354281634...732cd4e55be8d6... - Loading...
