Sound Blaster Live
  • whiz
    • Aug 2006
    • 48
    Sound Blaster Live
    My sound card is a "Sound Blaster Live" and has some "wincap" capacitors i don't know that brand...is it good?!
  • tiresias
    • Feb 2006
    • 489
    Re: Sound Blaster Live
    Welcome Whiz
    Capacitors on a sound card, in general, aren't particularly likely to fail. As you will have noticed, the vast majority of all the "bad cap" cases reported on this site involve the VRM sections of motherboards or the secondary side of PSUs. So realistically, you're probably OK.
    Still, Wincap is not a good brand as far as I can see. They're not very common - searching this forum turns up only a single hit, on this post - it's a mention of possibly failed Wincaps and Jamicons on, indeed, a Creative sound card:
    https://www.badcaps.net/forum/showth...ghlight=wincap
    A quick search in Google turns up a couple of references to failed Wincaps, in association with Lelon too - a notoriously poor brand.
    Still, if sound card isn't giving problems, and the caps haven't obviously blown/expanded, I wouldn't worry.
    • whiz
      • Aug 2006
      • 48
      Thank you Tiresia!
      The first thing i did before posting...it was a search for "wincap" and i only found the thread you mentioned too...
      i was very curious with this brand.
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • paparazzo79
        sound blaster Z SE ,How to check these caps?
        by paparazzo79
        Hi guys.
        I ordered the used sound card, but I got scammed.
        clearly these caps are probably in bad condition and need replacement How can I check them?
        It is the sound blaster Z SE sound card.
        And the bottom part is a lot scratched....
        08-12-2024, 04:54 AM
      • LEECH666
        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
        by LEECH666
        Good day ladies and gentleman!
        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
        01-19-2024, 05:46 PM
      • ktmmotocross
        Sound Blaster SB1740 not work after sparks when attach to working computer
        by ktmmotocross
        Hello have this Sound Blaster SB1740 that not work after sparks when attach to working computer. I not found any short on pcie pins. measured coils. one have 6V, second 12V and other have 0V and short to ground. i try to inject but looks like straight short to ground. i inject 1V 10A but nothing gets hot on thermocam, only wires. when i removed coil i found 12V on power side.
        anybody knows what is that rail for?...
        02-10-2024, 04:33 AM
      • Christos Tsiligiannis
        Marian Trace Alpha sound card repair help
        by Christos Tsiligiannis
        Hello to the forum.
        My name is Christos, I am new to the forum here and i am posting from Greece.
        So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
        To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
        So i tried asking for a schematic from the company and they would not give me one. Instead they...
        11-18-2024, 05:26 AM
