Replacing CCFL - Now only halfway lights up
  • duckboy81
    • Sep 2012
    Hello all,
    I ordered a couple of CCFLs to replace two broken ones and have finally wired them up. The entire setup has 4 CCFLs in the circuit (two of the original four are fine). Now my problem is, the 2 new CCFLs are only lighting up about halfway...I'm not too sure why this is happening. Anyone have any suggestions?
    Thank you!
    Re: Replacing CCFL - Now only halfway lights up
    Do the new pair light half way up on any pair of the lamp connectors?
    • Agent24
      I see dead caps
      • Oct 2007
      • 5085
      • New Zealand
      Perhaps they are designed for a higher voltage and don't have enough to light completely?
      Just my guess, I may be completely wrong!!
      -David VanHorn
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        maybe they are not connected right.like no return lead?
        plug that pair into the other channel and see if they work.i have gotten an occasional dud like 1 in several hundred but doubt you got 2 duds.
        • byroberta
          hp elitebook 840: lights up halfway
          by byroberta
          Hi, I have a problem with a hp elitebook 840: connecting the power supply, only the LED lights up. And from the button does not turn off. The CPU heats up. Screen is off.
          -I replaced a cracked capacitor on 3.3v
          -On the motherboard there are only 19v, 5v, 3.3v 1.05v
          -I reprogrammed the two bio chips.
          But nothing has changed.
          09-13-2022, 03:47 AM
        • ttmi100x
          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
          by ttmi100x
          Greetings everyone,
          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
          Upon closer inspection...
          07-31-2024, 06:36 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • mikey5791
          Help on Samsung Syncmaster T220 dead ccfl lamp
          by mikey5791
          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
          10-18-2020, 03:17 AM
        • Francesc V.
          Christmas lights - Something I am doing wrong
          by Francesc V.
          Hi:
          i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
          I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
          If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
          Could...
          03-11-2023, 07:38 AM
