MSI K8N Neo V2.0 high pitch hiss
  • lordshade
    • Jun 2011
    • 9
    I have an somewhat old mobo MSI K8N neo V2.0 and was using a sata 2 hdd, even though the mobo has sata 1.
    Everytime the HDD seeks at high speeds using read/write cache, I hear a somewhat intermittent high pitch hiss(frecvency related i guess) comming from the caps or mosfets or microcontrolers around the sata slot. I can't seem to find the exact location because of the tight space.
    Untill now about 2 caps marked KZG 6.3v 1500uF went bad and i had to replace them. The mobo boots up and I can even overclock the processor/ram and it's perfectly stable...but because of that hissing I guess that something else is broken or almost broken around there.
    Also the hdd doesn't have the required performance it feels sluggish for example when I'm download something at 5-8mb/s.
    And the CPU voltage varries too much...using 1.65v in bios, the mobo sensor shows it at 1.63v and drops every few seconds to 1.60v and rarely to 1.59v.This dropout stays the same when the CPU is idle or in full load.
    The power supply is checked and double checked and also it's 1y old, has 500W, voltage is within the 5% limit even in full load, so no issues here.
    Is there any chance that one of the mosfets could be damaged ? or the only thing needed is recaping?
    I have visualy checked the other capacitors and they seem ok, I didn't want do solder/desolder them too may times because of the increased risk of board damage.
    The mobo has some KZE 25v 850uF caps, and I can't seem to find the exact match. Would be ok if i replace them with 25v 1000uF ?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: MSI K8N Neo V2.0 high pitch hiss
    KZEs are good. What you're hearing there is coil noise and it's mostly normal. As for HDD performance, if you're using a torrent client, you need to tweak the disk cache settings.
    A working TV? How boring!
    • lordshade
      • Jun 2011
      • 9
      Also there is another issue I forget to mention: if the mobo is shut down but remains plugged in to power, there is a strange voltage commin from one mosfet just above the agp port, and from the usb and many more locations on the left of the CPU.
      I think it's on the 5v rail, but is quite lower than 5v...like ~4v Also when the board was new, at shutdown the keyboard and mouse were completly shut off.
      Now after I turn it off the keyboard remains active(I can play with num lock/caps lock/scroll lock leds) and there is a dim light in my mouse...one of the leds lights up(the one that shows current DPI) but like 1/3 of normal light intensity, and that's a sign it isn't powered up propperly.
      If the mobo is turned on the voltage on that line goes up to 5v and remains there.
      • c_hegge
        • Sep 2009
        • 5219
        Have you replaced -all- of the KZG caps? They are known for going bad without showing it. That could explain the noise, as more of the ripple is having to be filtered by the coils. What brand and series of capacito dis you use to replace the bad ones?
        The voltage on the USB when powered off could be because the motherboard is set to use the 5vsb rail to power them.
        Also, what brand and model is your PSU? Is it a good 500W, or a cheap no-name 500W (ie. a 200W with a 500W Sticker)
        • lordshade
          • Jun 2011
          • 9
          No I didn't replaced all the KZG, just the two that went bad with some ChemiCon LXJ i think(I can't see the label completly) 10v 1500uF. I didn't know their reputation at the time.
          The noise was there even long before i replaced the damaged caps but had a much lower intensity back then. Also when the mobo was new there wasn't any noise comming from it.
          PSU is inter-tech sl-500A..not a very renowned brand but the voltages are quite stable even under load.
          5V rail mentains a stable voltage of 4.90-4.91 no matter what i do
          12v keeps steady at 11.86-11.90v
          3.3v when idle is at 3.30v sharp...and in full load drops at about 3.26-3.28v
          Also i have around here some unused LXZ 6.3v 1500uf...they are good for something like this or i must find a more exact replacement?
          • c_hegge
            • Sep 2009
            • 5219
            There's one problem. The KZGs all have to go. they are notorious for failing without bulging
            There's another problem. LXJ aren't even close to being low enough ESR for this application. Use Nichicon HM or HN, or Rubycon MBZ or MCZ.
            You may have made the ripple going through the coild worse by using the wrong caps.
            That could be another problem. The voltages looking good on the DMM doesn't mean much. you could have stable voltages with high ripple. The SL prefix on the model suggests it's a Solytech/Deer, which can make some horrible PSUs. Could you post a picture of its internals?
            Those aren't suitable for use on a board. Use one of the series I suggested before (Nich HM or HN, or Ruby MBZ or MCZ)
            • lordshade
              • Jun 2011
              • 9
              Unfortunately I can't post pictures of my psu's inside because it's still in warranty, and second: I dont have anything that I can take pictures with.
              However the issue may be from previous psu...which was indeed a no-name and was used untill the 10v 1000uF caps inside started to bulge(about 2y or so). Maybe that shitty psu damaged something on the motherboard.
              That being said, next week I will go shopping for caps...I hope to find the ones I need.
              Any advice on how to spot counterfeited caps ?
              • c_hegge
                • Sep 2009
                • 5219
                Yes, don't use fleabay (except for one seller - egekecu). Get them from here and you won't have any problems with fakes. These (https://www.badcaps.net/store/produc...roducts_id=136) should do fine in place of the 1500uF caps. There may be other good suppliers too, depending on what country you're from.
                If your previous PSU had bad caps, then all it will probably have damaged is the motherboard's caps.
                • lordshade
                  • Jun 2011
                  • 9
                  Thanks alot for all the help.
                  • karatzdi
                    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                    by karatzdi
                    I know some might say... just buy another one. Sell it as parts..!
                    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                    Spent some time downloading the Service...
                    06-11-2024, 08:38 AM
                  • RetroComputingGrotto
                    Viewsonic VA2010wb (High Pitch Squeal At Power On)
                    by RetroComputingGrotto
                    I've got a monitor on my workbench at the moment that makes a high pitch squeal (that I cant hear as my ears are too old) when you power it on and lasts a couple of seconds before quitening and apparently it can be heard at regular intervals whilst on.
                    On opening up the monitor and looking at the PCB the usual suspects showed their heads so I have already replaced all the electrolytic capacitors.
                    The other issue that was reported with this monitor was the fact it took ages to start displaying anything after pressing the power button.
                    What component(s)...
                    02-03-2025, 06:00 AM
                    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                    by sam_sam_sam
                    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                    I tested the battery cells there are installed right now and they are testing good with no issues that I...
                    02-04-2025, 08:08 PM
                  • competition
                    Replacing capacitors in Evga PSU
                    by competition
                    I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
                    11-14-2025, 11:12 AM
                  • DynaxSC
                    Extreme High Current & Low Voltage Short Killer ??
                    by DynaxSC
                    Hi Folks
                    I'm looking for a extreme high current short killer solution for a reasonable cost.
                    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                    After taking off the socket, the shorts dissappear again.
                    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                    10-15-2024, 10:13 AM
