Problem
  • Rookie
    • Aug 2006
    Problem
    Hokay, here it is:
    I own a fairly high end system - Athlon 64, 1gb RAM, Radeon X800GTO, yadda yadda. Up until a few months ago, it was running on an ASUS A8S-X mobo, which displayed a number of performance issues - sometimes it failed to boot into XP, it crashed a lot and generally wasn't too reliable. I then chose to upgrade to an ABIT AT8. Now, this motherboard exhibits even weirder symptoms - sometimes it point blank refuses to boot; I have to reset it or power down and then back up again. It also has an annoying habit of crashing whilst I'm gaming for longer than, say, a few hours. It's also developed an annoying stutter, which affects games, music, movies, whatever I happen to be doing at the time.
    Naturally I was worried about what this could mean, so a Google of the symptoms brought me to your site, where I read up on "capacitor plague". I've opened her up and checked all the capacitors on the board, and they seem fine - they're not deformed, bent, twisted or oozing brown crap out of them. I'm pretty sure the PSU is the source of my problems, since the symptoms only really develop once the system comes under heavy load. System temperatures also seem well within tolerance.
    I therefore come before you asking a second opinion: Mobo or PSU? Replacing either wouldn't be too much of a problem.
    Specs:
    AMD Athlon 64 3700+ @2.2GHz
    1gb Corsair XMS
    ABIT AT8
    Samsung DVD+/-RW DL
    36.6gb WD Raptor
    160gb Maxtor DiamondMax 10
    Radeon X800GTO
    ThermalTake 430w "Silent" (but not fanless) PSU.
  • tiresias
    • Feb 2006
    • 489
    Re: Problem
    Welcome Rookie, always nice to see another fellow Englishman
    All of your symptoms are relatively generic, and could be caused by a whole variety of either motherboard or PSU issues. Heck, even a quirky stick of memory could do this.
    Still, by far the most likely culprit now, I would say, is your PSU. If for no other reason than simply because the problems were not solved (they were actually exacerbated) when you tried a new MB.
    If you have a multimeter closeby, you could take voltage readings of the major output rails (3.3, 5, and 12vdc), both when the CPU and GPU, or other power-hungry components are idle, and when they're "maxed out" as far as power consumption is concerned. CPU power usage is highest when you use such a utility as BURNK7...
    PS. Unless you're bound by warranty issues or such - could you check which output capacitors your thermaltake brand PSU is using?
    • davmax
      • Dec 2005
      • 899
      Re: Problem
      Certainly check the system voltages. Do you have monitoring software loaded into Windows? Most motherboard manufacturers supply this utility. Check the voltages at different system loads keeping the monitor software running. See if any voltage drops with load.
      I hope you have tested the memory thoroughly eg using Memtest 86?
      Gigabyte EP45-DS3L Ultra Reliable (Power saver)
      Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
      160Gb WD SATAII Server grade
      Nvidia 8500GT 256Mb
      160Gb WD eSATAII Server grade for backup.
      Samsung 18x DVD writer
      Pioneer 16x DVD writer + 6x Dual layer
      33 way card reader
      Windows XP Pro SP3
      Thermaltake Matrix case with 430W Silent Power
      17" Benq FP737s LCD monitor
      HP Officejet Pro K5300 with refillable tanks
      • Rookie
        • Aug 2006
        Re: Problem
        Yeah, I have ABIT uGuru installed - when idling the voltages seem okay (give or take .01 or .02 of a volt), but I haven't checked them when it's under load.
        I'm pretty certain it's not my RAM, since I left it to crunch MemTest overnight and it managed multiple passes without a single error. I'm going to swap out the PSU with another one (which should be here tomorrow, but I'm on holiday from then so I'll sort it when I get back) and see if it makes any difference.
        Cheers for the responses guys.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          Re: Problem
          post the brand of psu.it could be most anything causing the symptoms but a crap psu is one of the top suspects.
          hell pop the top and have a look.
          • tiresias
            • Feb 2006
            • 489
            Re: Problem
            ThermalTake 430w "Silent" (but not fanless) PSU...
            The output caps in there could certainly do with checking.
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
            • perzyk23
              Lenovo T580 - LCD Panel problem - error 0288
              by perzyk23
              Good morning,
              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
              10-25-2024, 12:42 AM
            • lazaro.089
              Asus Zephyrus M16 / GU603ZW problem
              by lazaro.089
              Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
              CPU: Core i9-12900H
              Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
              Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
              The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
              08-26-2025, 06:33 PM
