how good are panasonic FL caps?
  • mariushm
    • May 2011
    • 3799
    Re: how good are panasonic FL caps?
    Oh give me a break.
    FJ: 1140mA ripple, 0.03 ohm esr , 8x11.5 2000 hours
    FM: 820uF 6.3V ±20% 3000 Hrs 1240 mA 0.041 Ohm 8x15
    FR: 820uF 6.3V ±20% 6000 Hrs 950 mA 0.056 Ohm 8x13
    If you think 0.03 vs 0.05 is gonna make a difference, especially since the measurements are done at 20c and the capacitors are probably gonna stay at 20c for 0.1% of their usage... or that the designed relied on FJ caps handling over 1000mA ripple...
    Yes, HM will be almost spot on, but good luck finding it in retail shops since it's discontinued. This site's shop maybe has it.
    • Andre Gilbert
      by Andre Gilbert
      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
      11-20-2024, 08:52 PM
    • AquaMan Ua
      by AquaMan Ua
      05-17-2025, 09:40 AM
    • stecos
      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
      by stecos
      Hi everyone!
      For my passion for technology I'm now collecting several...
      11-28-2022, 11:39 AM
    • aa10aa10
      Panasonic Toughbook CF-33 mk1 BIOS repair
      by aa10aa10
      Good day,
      I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
      I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
      01-21-2025, 06:13 AM
    • Mnawar27
      Panasonic CF-H2AU24EF3 bios locked
      by Mnawar27
      Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
      I need help to remove it,
      thankyou all.
      SN; 2FKCA26876...
      11-16-2024, 08:00 AM
