how good are panasonic FL caps?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    cuz i also have another motherboard that might need a pre-emptive recap. its an asus a8v socket 939 amd athlon 64 board and uses the following caps:
    4 x 1000uF 16V 0.018 Ohms 1870mA Nichicon HM(M) A0506 8mm(Ø) x 20mm(H) @ CPU VRM In Area
    6 x 1500uF 6.3V 0.021 Ohms 1870mA Nippon Chemicon KZG 8mm(Ø) x 20mm(H) @ CPU VRM Out Area
    i found a panasonic FL 1800uF 6.3V 8mm(Ø) x 20mm(H) that might be a possible candidate to replace the KZGs. however, i cant find any datasheets for panny FL that state the ripple and esr of the FL caps. so i need some advice here if panny FL are good and suitable. also, is FJ better than FL?
    the board is still currently working fine and im surprised that im able to overclock my cpu to the holy grail of 3ghz using only 1.375V in the BIOS with these lemon caps: HM with faulty electrolytic formula used between 2002-2005 and the infamous FAIL of KZG.
    im probably thinking of leaving it overclocked 24/7 to see how long the lemon juice will last haha~ that way, i have motivation to recap it once its spoilt lol (on a serious note, i must recap my socket 478 875p board first keke )
  • c_hegge
    • Sep 2009
    • 5219
    Re: how good are panasonic FL caps?
    Panny FL will be fine to replace the KZGs. Spec wise, I think they may be slightly superior, but panny don't publish the datasheets.
    What's more of a concern is where you are getting them from. Panny don't normally sell their caps to anyone except for motherboard manufacturers, so you could have fakes. Do you have any pictures of them?
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3266
      • Singapore
      hmm got another question. since the difference in capacitance for each cap is 300uF, is it okay if i replace the 6 KZGs with 5 FLs? the total capacitance will still be 9000 uF, but will it affect the esr and/or ripple if i use 5 caps instead of 6? please advise. thanks.
        master hoarder
        • May 2008
        • 12175
        Just use all 6 caps, even if the capacitance is a little higher. I am pretty sure it won't cause a problem. Actually, I'm surprised the VRM output has only 6 caps at 1500 uF. Most boards with so few caps usually have 2200 or 3300 uF with same or better-rated capacitor series (in terms of ripple current and ESR).
        The Nichicon HM maybe be fine. IIRC, 2004 was actually the last year for their problems. Most of 2005 (if not all) should be okay. And definitely don't change them unless you are sure you are getting real Panasonic FL caps. Lots of fakes on ebay.
        As far as Panasonic FJ and FL - I'm not sure which is better, but I do remember reading an old post here that they are more or less equivalent in terms of ESR just going by their case sizes.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3266
          • Singapore
          just recapped the board with panny FLs today. they seem genuine as i have other panny FJs to compare the markings against. could be very good fakes but doesnt look like it. keke~
          however, when i measured their in-circuit esr, i was disappointed to find they had slightly higher esr than the KZGs. the FLs had roughly 22-23 milliohms esr. btw, i did replace all 6 caps, instead of using only 5. i figured more caps in parallel wud mean better esr and wanted to compare it against the KZGs esr-wise.
          maybe i should have gotten sanyo WGs instead but hesitated as they had two different versions of 8x20mm caps. one with 19 milliohms and another version with 16 milliohms. not sure which one i wud get and didnt wanna play the cap lottery. so went with FLs instead... ah well... lesson learnt. only stick with products with known published stats and figures...
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3266
            • Singapore
            lol had another scare yesterday when i tried to boot winxp with the new caps. it wud keep freezing 5-10 secs into the boot screen. also tried ubuntu off a live dvd and it also crashed with a kernel panic about a cpu related error.
            had a scare then. thought i might've hosed the board during soldering or didnt seat the cpu back in the socket properly. (those things have got so many pins!)
            i then decided to run memtest for a few passes to find out what is the root of the freezing problem. surprisingly, memtest returned zero errors after 4 hrs and didnt freeze either after running for 4 hrs.
            then i decided to boot ubuntu off the live dvd again and this time it booted without problem. i rebooted and tried it again to make sure it wasnt a fluke and it still consistently booted without error. tried booting it a few times with the cpu overclocked to 3ghz and it still booted fine without error. phew~
            i then proceeded to boot winxp again and it succeeded too! yay! but lest the celebration be premature, i decided to stress test the cpu overclocked with both occt cpu tests. both tests ran for one and a half hours each without errors or freezing. so oh yay the system works fine again.
            im guessing the earlier freezing problem occured because the FL caps i bought most likely were old stock and were kept for donkey years and so needed a few hours of burn-in to restore their oxide layer to working condition. im just glad i finally had my first successful recap after my earlier failed attempt to restore my msi 875p board to working condition. well much better for my morale now...
            • theOracle
              • Nov 2012
              • 163
              this is not true, both Digi-Key and Mouser are both listed on the Panasonic website as authorized distributors of Panasonic electrolytic capacitors in USA! - Both of these companies will sell even a single capacitor, no minimum order.
              __________________
              the BIG 4
              ~~~ the top tier of low-ESR electrolytic capacitors ~~~
              • retiredcaps
                • Apr 2010
                • 9271
                I think c_hegge meant just the FL series is not available to consumers possibly because they are discontinued and replaced by FM?
                Of course, Panasonic's low ESR caps like FR, FM and FC have been widely recommended here and available from both digikey and mouser.
                --- begin sig file ---
                --- end sig file ---
                  master hoarder
                  • May 2008
                  • 12175
                  Actually FM/FR are lower class than FL, FJ, and FJS. But yes, IIRC, FL, FJ, and FJS are available for (possibly larger) manufacturers only.
                  • theOracle
                    • Nov 2012
                    • 163
                    without spec sheets being available, how can you make this statememt? - Are you Kreskin?
                    __________________
                    the BIG 4
                    • c_hegge
                      • Sep 2009
                      • 5219
                      We do have a leaked Panny FJ datasheet somewhere here.
                        master hoarder
                        • May 2008
                        • 12175
                        In Xbox 360s, I often see Nichicon HN, Rubycon MCZ, Sanyo WG (very rarely, and only in older 360s) and Panasonic FL used intercheangeably.
                        And IIRC, according to PCBONEZ, FL and FJ are more or less equivalent. I think there was indeed a leeked partial FL/FJ data sheet here somewhere (I tried looking for it before but couldn't find it, though).
                        As far as FJS - those are probably more on par with Rubycon MBZ, again based on what I have seen on computer motherboards.
                        • sofTest
                          • Aug 2008
                          • 361
                          FJ datasheet enclosed.
                          Be a mensch
                            master hoarder
                            • May 2008
                            • 12175
                            ^ Wow, THANK YOU!!!
                            • ChaosLegionnaire
                              HC Overclocker
                              • Jul 2012
                              • 3266
                              • Singapore
                              just an update, after "burning in" the FL caps i had by running them for a couple of weeks, i measured the esr again and found them to be the same with the KZGs. so i think we can assume FLs and KZGs have the same specs esr-wise.
                              cos if u rank the caps in descending order of esr, u have FJ > FM > FR. (note: the 10x12.5 and 10x20 FM and FR have got different esr). so if u go by the second letter of the series, it seems the higher alphabet has higher esr so FL shud have slightly higher esr than FJ.
                              just trying to make an educated guess, so if someone else needs to use FL they know where it stands instead of groping in the dark like me...
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                just got a hp sff box with 1 failed 1800@6.3 fl.
                                box is clean and no power supply problems or dead fans.
                                odd.
                                • ChaosLegionnaire
                                  HC Overclocker
                                  • Jul 2012
                                  • 3266
                                  • Singapore
                                  lol no surprise there if its a sff toaster box. even good caps die due to high temps.
                                  where is it situated anyway? sumtimes there are certain deadzone areas in cases with still air and no moving air. the fl might be in one of those deadzones.
                                  • jesusconverse
                                    • Mar 2013
                                    • usa
                                    hey guys can you tell me if these are fakes or not ,please reply quickly so i may buy them or not
                                    http://www.amazon.com/gp/product/B00...pf_rd_i=507846
                                    • mariushm
                                      • May 2011
                                      • 3799
                                      Why bother, when you can get Panasonic FM and FR from Digikey or Mouser or Newark/Farnell ?
                                      http://www.digikey.com/scripts/dksea...ity=0&PV13=229
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        FM and FR are not on par with and are not suitable substitutes for FJ. Those places do have Nichicon HM, though, which are the same as FJ.
                                          by momaka
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • black6host
                                          Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                          by black6host
                                          Good day!
                                          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                          I'm going to replace the caps and I'll be the first...
                                          02-06-2024, 08:22 PM
                                          EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
                                          by momaka
                                          I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
                                          So, here is the...
                                          06-06-2020, 04:39 PM
