how good are panasonic FL caps?
  • mariushm
    • May 2011
    • 3799
    Re: how good are panasonic FL caps?
    Oh give me a break.
    FJ: 1140mA ripple, 0.03 ohm esr , 8x11.5 2000 hours
    FM: 820uF 6.3V ±20% 3000 Hrs 1240 mA 0.041 Ohm 8x15
    FR: 820uF 6.3V ±20% 6000 Hrs 950 mA 0.056 Ohm 8x13
    If you think 0.03 vs 0.05 is gonna make a difference, especially since the measurements are done at 20c and the capacitors are probably gonna stay at 20c for 0.1% of their usage... or that the designed relied on FJ caps handling over 1000mA ripple...
    Yes, HM will be almost spot on, but good luck finding it in retail shops since it's discontinued. This site's shop maybe has it.
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • black6host
      Replacement caps for Samson Resolv studio monitor 65A Amp board.
      by black6host
      Good day!
      I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
      I'm going to replace the caps and I'll be the first...
      02-06-2024, 08:22 PM
      EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
      by momaka
      I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
      So, here is the...
      06-06-2020, 04:39 PM
