Vizio TV solder issue
  • barecycles
    • Sep 2012
    • 3
    Greetings:
    Forgive my ignorance but this is my first attempt at dignosing a possible cap problem in a TV. My experience with capacitors has been in the HVAC industry.
    I have a Vizio LCD TV that has a "jumping" picture. The best way I know to describe is it is similar to a rolling horizontal hold problem in a old tube TV. While looking a the backlight inverter board I saw 2 caps that had solder joints that looked like the attached picture. Would anyone venture a guess if this could be related to the picture problem and what causes such an occurence? I have since cleaned the solder joints with alcohol and the problem appears to have cleared up but I am a little concerned still. Is this a sign the caps may be on their way out?
    Thanks!
  • lilmonk3
    • Apr 2012
    • 259
    Re: Vizio TV solder issue
    I have had 3 Vizio 42 in with those style inverter boards... 1 of them flashed like a strobe light .. replaced caps on master and slave boards fixed it.. Another one had sound no picture and replaced caps on master and slave boards fixed it. 3rd one had Green reflections around images on screen, removed the LVDS cable and cleaned cable ends with eraser and rubbing alcohol fixed it..
    • barecycles
      • Sep 2012
      • 3
      Looks like this "fix" was short lived. It has gone back to jumping around soon after turning it on. Once it heats up it never jumps again. Im stumped.
      • Kent_Diego
        • Jan 2012
        • 5
        That solder job had a little flux residue but looked like it should work fine. Maybe you can find a new main board for this if you look around. Does not sound like a bad cap issue.
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • CyberPhoenix
          Issue with picture quality of Sony bravia TV
          by CyberPhoenix
          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
          01-22-2024, 02:08 AM
        • gavric
          Vizio M70-C3 Half picture is bad, main board on its last leg?
          by gavric
          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
          When tv powers on vizio V logo shows nice on whole screen. picture 1
          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
          When i click video to start playing picture goes black(like when you change...
          09-02-2021, 08:55 PM
        • jm1234
          Solder joints on heat sinks matter?
          by jm1234
          solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
          I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
          04-28-2024, 04:38 AM
        • EazyBone
          Vizio P759-G1, Tcon issue?
          by EazyBone
          Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
          Any help appreciated
          https://youtu.be/tPeV2Q7TXIQ?feature=shared
          03-22-2024, 03:25 PM
