Failed MCZ rubycons
  • EIBM
    MBZ > KZG
    • Apr 2012
    • 18
    Failed MCZ rubycons
    Normally rubycon is my favourite, but not when it comes to the mysterious MCZ series.
    A friend of mine happened to always be talking about the MCZ series and how thermally sensitive they were. Well I ended up taking home quite a few suffering thinkcentres which had MCZs in them, generously too.
    What's more curious is that only ones with a specific micro farad rating blew up.
    10v, 1000uF -- OK
    6.3v, 1800uF -- OK, known to silently fail (hard to replace! skinnycaps)
    10v, 1500uF -- BAD BAD BAD!!!
    So there's a huge variance within the MCZ series in itself.
    THere were some blown up KZJ chemicons beside the MCZs as well, but that's not much of a surprise (KZJ/KZGs blow up all the time).
    Without further ado, I'll have to order some replacements for these MCZs... probably panasonic, sanyo, or elna. But I'd like to know if anyone else had particular issues with *certain* MCZs.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Failed MCZ rubycons
    Elna doesn't make low esr iirc. They are more for audio applications.
    Geniune MCZ is good. The only times I hear of them blowing is in super toasty usff boxes and imac G5s, both of which will cook any electrolytic cap (they are better off poly modded).
    MCZ is by no means in the same category as KZG or KZJ.
    sigpic
    (Insert witty quote here)
    • EIBM
      MBZ > KZG
      • Apr 2012
      • 18
      #1 ELNA does make capacitors suited for system boards. I own computers with plenty of ELNAs. Please explore their website for more info.
      #2 These are genuine MCZ. Now there were also MBZs nearby, and they happen to be perfect. I'm quite fond of the MBZs, very reliable.
      #3 If MCZs aren't in the same category of KZG/KZJ... from my general observances, I'm seeing more dead MCZ than KZG. I have computers amply filled with both types (sigh).
      And yes these ARE genuine. IBM is a respectable vendor. Furthermore, as I outlined above, only the 1500uFs failed. This is interesting.
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        It makes me ponder if there's some sort of defect in the MCZ series, in a similar way that there was with Nichicon's HN/HM series (2001-2004 date codes) and Chemicon's KZG/KZE. One bad series of capacitors is possible even from a stellar Japanese company. Of course, I don't have much experience with Rubycon's MCZ capacitors so I cannot speak much of it... but maybe with the MCZ series, the oxide layer of the capacitor is better kept with lower specs (in terms of uF and/or voltage), or perhaps something is amiss with the electrolyte or maybe ESR wise. I can see why they'd fail on motherboards out of all the places with the kind of stress and surge current they'd be subject to that way (in the same manner that capacitors are 10x more likely to fail quicker, I believe, on motherboards than they are in well designed power supplies, and in turn how they are just more likely to fail in high frequency devices that need 100% stable power).
        I could be wrong, of course. It's just if there are a large reports of failure from a series of capacitors, even in well ventilated systems, then something may be wrong.
        • UraBahn
          Scrapheap Hound
          • Nov 2004
          • 165
          I have seen blown MCZ myself, though sadly I was not paying that close attention to the uF values. I partially agree with Ratdude747, they are nowhere near as bad as KZG/KZJ with regard to thermal instability, but they seem to bloat a little bit more than I'd like. Some that seem to have silently failed (for whatever reason, I acquired this board from a scrap heap) were 6.3v, 1800uf, with date code T0604.
          It could be that they are all too often used in applications that simply demand too much of an aluminum electrolytic (be it thermally, ripple-wise, or otherwise.)
          To clarify EIBM's post a little, Elna don't normally make too many ultra-ESR radial aluminum electrolytic caps, but they do make them. Elna RJS (was it?) being one example. I've also seen an old Slot 1 board with big ELNA caps around the CPU slot... I may have to track it down to find out more about it.
          The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
          I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
          • mariushm
            • May 2011
            • 3799
            As they're 10v rated, I would guess the 1500uF ones are probably on the 5v coming from the power supply, while the 6.3v 1800uF are on the VRM side (chosen perhaps to keep the esr low)
            Are you sure it's not a problem of excessive ripple from the power supply mixed with heat from the VRMs? The 1800uF may be close enough to the heatsink to be cooled a bit by the cpu fan.
            How about some pictures of the boards?
            • UraBahn
              Scrapheap Hound
              • Nov 2004
              • 165
              That could be. The VRMs could have been managing some killer ripple.
              As for pics, well I already pulled alot of caps from the board, and I think I already got rid of the problem caps, but I'll give one. However, come to think of it, this board likely came from one of those cramped little systems. Interestingly tho, this system may have used an external brick for power.
              Permit me this rant: Pentium 4's have no right being in pizza boxes. No. They just put out way too flipping much heat.
              • UraBahn
                Scrapheap Hound
                • Nov 2004
                • 165
                Absent from the picture are all the KZJ I unceremoniously yanked off with my fingers. :P Also some suspect Ruby MCZ were pulled in the same manner.
                I got this board as a cap donor, little more. It had rubycons as well as some polymer caps of the value I was looking for, so I picked it up.
                • mariushm
                  • May 2011
                  • 3799
                  Nice. After you get the board working you should also measure the temperature of those inductor coils.
                  I wouldn't be surprised to see those coils hovering at 40-60c
                  And the caps behind that heatsink... I guess it depends on the case but it could be there's little airflow back there.
                  • UraBahn
                    Scrapheap Hound
                    • Nov 2004
                    • 165
                    I have no plans on getting this board working again, I bought it just for the caps. :P
                    I wouldn't doubt, however, that the inductor coils would get searing hot.
                    • EIBM
                      MBZ > KZG
                      • Apr 2012
                      • 18
                      Yeah I'll get some pictures of the systemboards, as well as outline the caps that didn't fail (which are nestled in the same area).
                      It has nothing to do with the PSUs. These are IBM FRUs (either made by delta or acbel), so they're engineered to a higher standard.
                      The caps inside these PSUs are either chemicon or nichicon (I opened them up and checked)... sometimes even rubycon! An awesome acbel I have uses rubycons.
                      Heat isn't an issue, and if it is, they're way too sensitive (as the caps nearby weren't affected except specific ones: which I outlined above).
                      I have a thermo-nuclear SFF P4 thinkcentre reaching 120C, and the MBZs (and even the KZGs!) were fine. I'm keeping the cooling stable (now), I just wanted to see how hot it could get. The heatsink did cause some burn marks to nearby surfaces.
                      • UraBahn
                        Scrapheap Hound
                        • Nov 2004
                        • 165
                        All that said, I still believe MCZ are just a touch thermal sensitive compared to MBZ and Rubycon's other series. Again, not nearly to the same extent as KZG/KZJ/TMZ/TMJ are.
                        Maybe we should record the date codes of failed Ruby MCZs? Perhaps it was a one-off, slightly faulty batch that was produced within a specific time frame. (Slightly faulty in the sense that it was a little over-sensitive to heat/ripple compared to normal.) For my two cents, the suspected ones I cut/removed were T0604.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Topcat had some MBZs which failed in well ventilated thinkcentres recently. '07 datecodes IIRC.
                          • UraBahn
                            Scrapheap Hound
                            • Nov 2004
                            • 165
                            Failed MBZ, huh...
                            What PSU was used on that ThinkCentre? Also, was it an IBM or Lenovo one?
                            • UraBahn
                              Scrapheap Hound
                              • Nov 2004
                              • 165
                              While we're on the subject of Rubycon...
                              Here's an obvious fake, "Rukycon"....
                              http://www.ebay.ca/itm/1000-Rukycon-...item415c9264b9
                              • PeteS in CA
                                • Aug 2005
                                • 3581
                                • USA, Unsure of Planet
                                UB, maybe you answered me before, but I missed it. Are you in Yolo County?
                                PeteS in CA
                                • severach
                                  • Aug 2007
                                  • 1055
                                  I've seen too many MBZ and MCZ fail where other brands don't so I don't consider MBZ and MCZ to be any better than the cheapies. The problem with bad caps isn't that they can't last. Some cheapies last a long time. The problem is that they don't all last. You can't tell from the label whether a KZG, MBZ, or MCZ will last or fail early.
                                  With a Sanyo, Panasonic, Nichicon, and other series from UCC and Rubycon you can tell.
                                  sig files are for morons
                                  • EIBM
                                    MBZ > KZG
                                    • Apr 2012
                                    • 18
                                    Okay here are the images.
                                    In the first '06 thinkcentre, you'll notice the 1500uF MCZs have blown (it's more difficult to see the burnt electrolyte on the photo). The ones circled in blue show no physical signs of bursting. I've observed a multitude of these same machines with the same MCZs, and ALL of them exhibit exploding 10v @ 1500uF MCZs.
                                    In this '05 thinkcentre, a whole load of the KZGs are slowly dying... being a total of *28*, it'll be a pain to replace.
                                    Finally, in the 2005 intellistation, that one big KZG has shown signs of popping. The other KZGs are fine as I keep this thing cooled *very* well. The rest of the caps are nichicon HM(M), but they obviously must have been from a good batch. Oh, and a handful of oscons.
                                    --> so the conclusion. KZGs seem to pop intermittently, and MCZs seem to be affected by a certain farad range?
                                    Regarding MBZs, all five of those IBM machines contain MBZs and they are PERFECT. I do not have to replace them.
                                    Later *Lenovo* quality thinkcentres may have bad PSUs (I've seen some with bestec): and I did see many Lenovo-made computers with low quality components, including OST and G-Luxon capacitors.
                                    All of these machines in question are pre-2007.
                                    • Wester547
                                      • Nov 2011
                                      • 1268
                                      • USA.
                                      If you don't mind me asking, a good batch does of course mean post-2005 date codes (since I imagine everything from 2001-2004 must be bad ^^; ), right? But I also wonder if MBZ and MCZ failures stem from PSU problems. Also, I meant KZG/KZJ, not KZE. ^^; Even if the PSU had good capacitors, something else could be wrong, though it's hard to say what.
                                      • UraBahn
                                        Scrapheap Hound
                                        • Nov 2004
                                        • 165
                                        Why yes sir. I live in Woodland to be exact.
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                        • Ady2017
                                          Are there any datasheets available for Elna RJG capacitors?
                                          by Ady2017
                                          I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                          05-25-2025, 02:19 PM
                                        • modtool
                                          Lenovo Legion 5 15ARH05H, NM-D281 Rev 1.0, "BIInitializeLibrary failed 0xc0000185" and bios freezing
                                          by modtool
                                          Dear members,
                                          I have a problem with this machine that still I can't solve, I hope some of you can suggest me something.
                                          I was the first one to open the machine and touch the mainboard, in fact the Lenovo seal was intact the first time that I unscrewed all the internal screws.
                                          The ower told me that it was working very good until Windows kicked "something like a firmware update" (owner's words) then the system started acting weird.
                                          When you try to start it, some seconds after having pressed the power button, Lenovo splashscreen appears, then after 1 second, in the...
                                          01-15-2024, 08:56 PM
                                        • Olkus
                                          Elna capacitors - fake?
                                          by Olkus
                                          I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
                                          09-01-2023, 02:45 AM
                                        • gurj1979
                                          Surface Laptop 1769 SSD Failed KUS040202M-B000
                                          by gurj1979
                                          Hey guys,
                                          I've got a Surface Laptop 1769 (the nasty cloth type palmrest) which has a failed 512GB Samsung PM971 (KUS040202M-B000).
                                          These are on BGA291, but I don't know which is equivalent to KUS040202M-B000.
                                          AliExpress has this but it's expensive.
                                          Can anyone help me find a reasonably prices equivalent which I can use as a replacement ?
                                          Or which NVMe can I remove it from ?
                                          02-17-2025, 04:02 PM
