Ouch!!! Gigabyte using FAKE CAPS?!
  • Shocker
    Banned
    • Dec 2011
    • 635
    I have a few Gigabyte motherboards that appear to have counterfeit Rubycons and Nichicons (from the factory, not recapped).
    One of those boards had two types of Nichicon HM (1000uF 6.3V 8x11.5) with poor labelling. One has the name Nichicon printed unclearly, and on the other the fonts are wrong. In the VRM there are four OS-CON SEPC 560uF 4V 8x9 with flat, rubber bungs (I thought OS-CONs had epoxy bungs ) and also four Nichicon HN 680uF 4V 8x9 (with shiny green sleeves and black print) with bullseye bungs . It also had Rubycon MBZ 1500uF 16V with the series letters "MBZ" printed right next to each other instead of spaced further apart and the name Rubycon a bit small. I'm even more suspicious after seeing that the small 100uF 10V caps were SWCON and that when I removed the northbridge heatsink there was NOTHING to fill the gap.
    Another board had MBZ with the same tightly grouped "MBZ" and small "Rubycon" in 1500uF 6.3V 8x20. The 3 in 6.3V is also a bit large. It also had 1000uF 6.3V 8x11.5 MBZ that looked real.
    The Chemi-cons (KY, KZE and KZG) I saw on some of the boards looked fine. Still, Gigabyte
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: Ouch!!! Gigabyte using FAKE CAPS?!
    sounds like older boards. If they had MBZ's in them they probably are. MBZ is a discontinued series.
    • Shocker
      Banned
      • Dec 2011
      • 635
      They are older models. Fake caps being used for only a short time could be reasonably blamed on stupidity. But the two boards I mentioned were made in 2006 and 2003 (if I'm correct, and respective to the order I mentioned them in the original post). And penny pinching is the ONLY reason why a manufacturer would want to leave out thermal material.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        the sepc i have on hand have flat bungs.
        no bullseye.
        green hn/hm sound fishy to me.
        time for pics!
        wonder if the whole board is a fake.
        • lti
          • May 2011
          • 2558
          https://www.badcaps.net/forum/showth...p?t=588&page=3
          Look at the discussion starting at post 51. I am guessing that these are the same green caps.
          • Shocker
            Banned
            • Dec 2011
            • 635
            Yep, they're the ones.
            Even ASUS didn't stoop this low. Did they...
            Can anyone suggest a motherboard manufacturer that doesn't use fake caps and isn't ASUS, AsRock, ECS, or PC Chips .
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5045
              • US
              msi, gigabyte. really, they don't anymore. it was a my bad at the time but they usually use polymers now anyways,
              • lti
                • May 2011
                • 2558
                They got close when they decided to sometimes use I.Q caps on their PII and earlier boards. I have seen Asus use either all Rubycon or all I.Q caps on the same model of board.
                It seemed like everyone used I.Q caps back then. My old Compaq uses those caps, and they haven't needed to be replaced yet. That may be a record.
                • c_hegge
                  • Sep 2009
                  • 5219
                  They don't need to. Nobody bothers faking Apaq caps, since even the real ones aren't that good.
                  • Shocker
                    Banned
                    • Dec 2011
                    • 635
                    Why do people even buy cheap crap???
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Smells like a motherboard from eBay.
                      ASRock B550 PG Velocita
                      Ryzen 9 "Vermeer" 5900X
                      Arc A770 16 GB
                      eVGA Supernova G3 750W
                      Alienware AW3423DWF OLED
                      • Shocker
                        Banned
                        • Dec 2011
                        • 635
                        Just got an old PC to take apart.
                        It has a Gigabyte motherboard (didn't check which model) and TWO Sanyo caps are bloated.
                        I checked in the PSU. No bloating.
                        Gigabyte
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Could it be a cooling problem?
                          • Shocker
                            Banned
                            • Dec 2011
                            • 635
                            I don't know.
                            The PSU caps are some mixed general purpose crap, including a Fuhjyyu . And I think the PSU would get hotter than the motherboard. The PSU fan is okay.
                            Neither of the bloated caps are around the CPU so I don't have any other conclusion.
                            By the way, the hard drive seems okay. It's a Samsung SP0411N (yes, I know you hate them) and has 0 bad sectors.
                            • Wester547
                              • Nov 2011
                              • 1268
                              • USA.
                              I don't like Samsung either, for my hapless experience with their disc drives and TVs, and I imagine their hard drives (and maybe even floppy drives?) aren't much better, though I admit they make decent headphones/earphones and RAM. While the PSU does get hotter than the motherboard (potentially, unless the PSU is exceptionally well cooled) capacitors are still stressed far more on a motherboard so they're more likely to fail there. Sad to know Gigabyte suck at motherboards as much as they do PSUs. I thought outside of the northbridge, nVidia, and capacitor problems, that the K8NGM2 series was half decent, along with some others (if I'm not mistaken that's by Gigabyte though I also see it entitled as MSI-7207).
                              Samsung hard drives also may not be fantastic but at least they run cool and quiet. And those Sanyos could be fake.
                              • Shocker
                                Banned
                                • Dec 2011
                                • 635
                                DUH!!!!!
                                The Samsung drive I mentioned has a strange ultra-thin form factor, like Seagate U Series X (I have an ST310014ACE)/Barracuda 5400.1, all recent single-platter Seagate drives, and those infamous slimline Maxtors (Fireball 541DX/Fireball 3/DiamondMax Plus 8). Speaking of Maxtor, I have a 31536H2 (DiamondMax VL30). It actually supports AAM, but what's the point - this is "What drives you crazy." (A play on the Maxtor slogan)
                                As for that Samsung - cool? Actually seems warmer than some of my other drives (such as Barracuda 7200.7 40GB and 80GB). Quiet? Sure, but again I have drives that compare (ST340014A, WD800JD-00LSA0). So the key feature is the form factor.
                                • Wester547
                                  • Nov 2011
                                  • 1268
                                  • USA.
                                  In my experience, Samsungs run cool. Not cold (hard drives shouldn't run cold), but cool, or moderately warm at best. I've found the 7200.7s to run rather hot, but older 7200RPM drives (especially multiplatter ones) are just that - hot without decent cooling (unless it's near a vent). The older Seagates are indeed very quiet, especially with AAM enabled, though even they become noisy over time, at least for me (not in terms of bearings but the read/write heads becoming more unruly, especially with many power cycles). I'm surprised the KZGs on that Gigabyte were fine, along with the KZJs, but then heat is a huge factor in their eventual and indelible failure.
                                  • Shocker
                                    Banned
                                    • Dec 2011
                                    • 635
                                    You mean in the first post??? I meant "fine" as in "not fake", not as in working properly. That said, from my experience they look OK much of the time. But then again, you know how KZGs are. Just because they look fine doesn't mean they are fine.
                                    As for 7200.7 heat output, when I used a USB enclosure with ST380011A the temperature did fluctuate a lot. Sometimes barely warmer than the room, sometimes scorching. But that could have been caused by the enclosure too. You never know for sure. (And by the way the enclosure's dead and I don't have it anymore. I'm willing to bet the problem was bad caps. ) I don't have a complete comparison as I don't have an ST3160021A or any other 2-platter 7200.7, but the only drives I remember really getting toasty are 3/4 platter 7200.11s.
                                    Also, I got a Maxtor 84320D4 recently. I didn't actually use it for anything. It gave out when I was performance testing it . And I think I know why. Stupid bastard is much lighter than ST380011A. I dismantled it. Yes, it did have two platters. And it's still so light??? No wonder it died .
                                    • ben7
                                      Capaholic
                                      • Jan 2011
                                      • 4059
                                      Got some pics?
                                      I did see one board with sanyo WG on the VRM. ALL were bloated
                                      They seemed as legit as can be! The board did have some heat discoloration, so that may have been the culprit.
                                      Muh-soggy-knee
                                      • Wester547
                                        • Nov 2011
                                        • 1268
                                        • USA.
                                        That's usually why controller boards on external hard drives die - cheap capacitors that get scant airflow if any atop that.
                                        Well, I've had notebook drives last longer than that and they're much, much lighter.. I'm willing to bet that it's because A) Maxtor drives ran hot and B) Maxtor drives are trash. And yes, heat could be the cause of that board's failure.
                                        • DynaxSC
                                          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                          by DynaxSC
                                          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                          General test conditions:
                                          - Tested with Core i5 6500 and Core I7 6700K - no difference
                                          - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                          What is wrong:
                                          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                          03-21-2025, 06:23 PM
                                          Thermal pad thickness for various laptop GPU / Graphics Cards
                                          ASUS Dual RTX 2070 OC 8GB
                                          ASUS ROG STRIX RTX 3080 OC
                                          ASUS ROG STRIX RTX 3090
                                          ASUS TUF Gaming RTX 3080 OC Edition
                                          ASUS TUF GTX 1660 S-O6G GAMING
                                          EVGA RTX 3060 Ti XC GAMING 8GB
                                          EVGA RTX 3060 XC GAMING 12GB GDDR6
                                          EVGA RTX 3080 FTW3 ULTRA GAMING
                                          EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                          EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                          Gainward RTX 2080 Phoenix GS Specs
                                          Gainward RTX 3070 Phoenix 8GB
                                          Gainward RTX 3080 Ti Phoenix
                                          GIGABYTE AORUS RTX 3080 MASTER 10G
                                          02-09-2024, 08:08 AM
                                          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                          by momaka
                                          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                          And a shot of the label:...
                                          01-26-2022, 03:26 AM
                                        • nikovmiroslav
                                          Gigabyte A5 X1 Need Bios
                                          by nikovmiroslav
                                          Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                                          Gigabyte A5 X1
                                          From motherboard:
                                          S/N: 1TNH55ER1350895
                                          P/N: 6-77-NH55ERQY-D02-2CGB
                                          On sticker from the back of the laptop:
                                          S/N: SN21351J000657...
                                          08-24-2025, 09:15 AM
                                          Gigabyte AERO 16 XE5-73UK948HP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 XE5-73UK948HP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 XE5-73UK948HP boardview and 16 XE5-73UK948HP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 07:19 AM
