Is this capacitor still good
  • electro1
    • Jun 2012
    • 38
    • usa
    Application is on a flyback transformer powersupply circuit board cap is 85 deg temp. 330 uf 16 v cap brand is sm the esr is .10 ohms and the cap reading is 269.8 and tested with atlas 60 cap tester
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Is this capacitor still good
    My opinion is that as most caps have a 20% variance on the stated rating that it is not good.
    Is there a problem with the Board?
    Is the board's application such that a 85 degree temp cap would be working at the top end of its temperature rating.?
    Was it in circuit when measured?
    • electro1
      • Jun 2012
      • 38
      • usa
      all caps are polarized and out of circuit when measured I also have a 1uf 160v the meter reads 1.16uf and 3.6 for esr its not fully working im missing the -15 volts the screen displays a trace but there is no vertical difflection im currently desodering componets and testing them out of circuit. its sealed in a aluminum case so it must get quite warm in there. unit was made sometime in 1985
      • cook
        Good brands of run capacitor for house heat hump
        by cook
        Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
        Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
        09-13-2024, 12:53 PM
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • CoppellTVRepair
        Troubleshooting PFC with SPC1012T not raising output
        by CoppellTVRepair
        It has been a long while since I posted here to ask anything....hope you can help.
        I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
        I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
        03-09-2025, 10:38 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Fritter
        Power supply filter capacitor measurement in circuit
        by Fritter
        Hi
        Measuring a 400v 330uf capacitor across the bridge rectifier and in circuit with a multimeter on ohms. Measures 360 ohms both ways when polarity on the meter is changed. If this is normal, I'd like a brief lesson
        11-15-2023, 12:58 PM
