CapXon higher ripple?
  • J_K_M_A_N
    • Apr 2012
    • 17
    I am trying to replace 3 CapXon LZ series 1000uF 10V 10x12.5 capacitors and it is tough finding ones to match the ripple. The CapXon ones are 1500 ripple and the only thing I could find were these which are 10x16 (hopefully I have space for that height).
    Do the CapXon have a higher ripple than other capacitors? Am I just not looking in the right places? Can I try a lower ripple with a better capacitor?
    J_K_M_A_N
  • retiredcaps
    • Apr 2010
    • 9271
    Re: CapXon higher ripple?
    Nichicon HN according to
    is available in 10x12.50mm with 1760ma.
    --- begin sig file ---
    --- end sig file ---
    • mariushm
      • May 2011
      • 3799
      The one you selected will work.
      This one will also work at 10x16:
      http://search.digikey.com/us/en/prod...398-ND/2433532 (yes, it's rated for 16v, it will work fine)
      Newark has some options, 16v and 10x16 but again, higher v is fine.
      http://www.newark.com/panasonic/eeuf...r%20Capacitors
      http://www.newark.com/rubycon/16zlh1...w%20Capacitors
      This one will also work from the Badcaps store: https://www.badcaps.net/store/produc...roducts_id=174
      • J_K_M_A_N
        • Apr 2012
        • 17
        I can't seem to find those anywhere online though. Not even if I wanted to order 500 (which I don't )
        J_K_M_A_N
        • Agent24
          Dick Smith Q-1760 linear power supply filter capacitor question
          by Agent24
          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
          It has at least one problem.
          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
          I have already ordered a replacement potentiometer, so that's not an issue.
          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
          All are CapXon...
          10-21-2025, 05:39 PM
          by momaka
          03-15-2023, 10:17 PM
        • Ady2017
          Is it ok to use a capacitor with a much higher ripple?
          by Ady2017
          Hi all
          I am trying to source some new caps for the power board on my LG TV. The one I am currently struggling to find a replacement for has the specs:
          Sam Young KMG 680uf 50V with a rated ripple current of 973. According to the catalogue these seem to be a general purpose capacitor and it is not clear why LG have used them on the power board.
          I like to use Panasonic capacitors but most of these have got a ripple voltage of 2-3 times the figure of the original capacitor. My preferred FR capacitors are 3160 while the FC ones are 2215. Would going from 973 to...
          10-30-2021, 10:46 AM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • Antonynl
          What are typical ripple voltages on a laptop motherboard?
          by Antonynl
          I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
          So I have two questions:
          1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
          2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
          Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
          12-09-2022, 06:51 AM
