Is it ok to use a capacitor with a much higher ripple?
  • Ady2017
    • Dec 2017
    • 55
    Hi all
    I am trying to source some new caps for the power board on my LG TV. The one I am currently struggling to find a replacement for has the specs:
    Sam Young KMG 680uf 50V with a rated ripple current of 973. According to the catalogue these seem to be a general purpose capacitor and it is not clear why LG have used them on the power board.
    I like to use Panasonic capacitors but most of these have got a ripple voltage of 2-3 times the figure of the original capacitor. My preferred FR capacitors are 3160 while the FC ones are 2215. Would going from 973 to 3160 be way too over-kill and cause other problems? Are the FC series ok to use for a power supply board?
  • petehall347
    • Jan 2015
    • 4480
    Re: Is it ok to use a capacitor with a much higher ripple?
    higher ripple current is fine in my book .
    • PeteS in CA
      • Aug 2005
      • 3589
      • USA, Unsure of Planet
      • Reading, Education, History, Christianity
      Replacing a GP cap with a low impedance, high ripple current rating cap is usually OK. Unless it was a GP cap in a circuit needing low impedance, etc., the original part would not have been a misuse.
      PeteS in CA
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • joetristan
        Tantalum capacitor burning out
        by joetristan
        I’m using a 10 µF, 20 V tantalum capacitor as a decoupling capacitor across a 5 V supply. When I power the circuit, the capacitor burns out.
        At first, I assumed the tantalum capacitor was defective and replaced it, but the new one burned out as well when the circuit was powered.
        I then replaced the tantalum capacitor with a 10 µF, 63 V electrolytic capacitor. This time, the capacitor did not fail after powering the circuit.
        I do not understand why the tantalum capacitor burns up?
        02-11-2026, 03:43 AM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • samoelec
        Trying to understand how to find best replacement cap for old parts.
        by samoelec
        Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
        Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
        The power supply board is exactly the same from this post so I'll just steal it for now.
        I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
        04-01-2024, 03:39 AM
