CapXon higher ripple?
  • J_K_M_A_N
    • Apr 2012
    • 17
    I am trying to replace 3 CapXon LZ series 1000uF 10V 10x12.5 capacitors and it is tough finding ones to match the ripple. The CapXon ones are 1500 ripple and the only thing I could find were these which are 10x16 (hopefully I have space for that height).
    Do the CapXon have a higher ripple than other capacitors? Am I just not looking in the right places? Can I try a lower ripple with a better capacitor?
    J_K_M_A_N
  • retiredcaps
    • Apr 2010
    • 9271
    Re: CapXon higher ripple?
    Nichicon HN according to
    is available in 10x12.50mm with 1760ma.
    --- begin sig file ---
    --- end sig file ---
    • mariushm
      • May 2011
      • 3799
      The one you selected will work.
      This one will also work at 10x16:
      http://search.digikey.com/us/en/prod...398-ND/2433532 (yes, it's rated for 16v, it will work fine)
      Newark has some options, 16v and 10x16 but again, higher v is fine.
      http://www.newark.com/panasonic/eeuf...r%20Capacitors
      http://www.newark.com/rubycon/16zlh1...w%20Capacitors
      This one will also work from the Badcaps store: https://www.badcaps.net/store/produc...roducts_id=174
      • J_K_M_A_N
        • Apr 2012
        • 17
        I can't seem to find those anywhere online though. Not even if I wanted to order 500 (which I don't )
        J_K_M_A_N
          by momaka
          03-15-2023, 10:17 PM
        • Ady2017
          Is it ok to use a capacitor with a much higher ripple?
          by Ady2017
          Hi all
          I am trying to source some new caps for the power board on my LG TV. The one I am currently struggling to find a replacement for has the specs:
          Sam Young KMG 680uf 50V with a rated ripple current of 973. According to the catalogue these seem to be a general purpose capacitor and it is not clear why LG have used them on the power board.
          I like to use Panasonic capacitors but most of these have got a ripple voltage of 2-3 times the figure of the original capacitor. My preferred FR capacitors are 3160 while the FC ones are 2215. Would going from 973 to...
          10-30-2021, 10:46 AM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • Antonynl
          What are typical ripple voltages on a laptop motherboard?
          by Antonynl
          I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
          So I have two questions:
          1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
          2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
          Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
          12-09-2022, 06:51 AM
        • ADV
          Acer Ferrari F-20" monitor display interference and replacement capacitor selection
          by ADV
          Good day everybody
          I hope I'm posting in the right section - I am new to this awesome forum.
          I have received an ACER Ferrari F-20" LCD Monitor to repair.
          It produces interference lines on the image displayed and slowly rotates across the whole screen, with respect to the center of the screen. One rotation takes about 4 minutes and the cycle repeats over and over.
          For some reason the On Screen Display Menu is not affected when switched on with the Menu button.
          I opened the external 18V power supply and see no bulged capacitors...
          11-02-2021, 09:32 AM
