I have a lanparty nf3 board.I have united chemichon kzg(I got the chemichon from reading in the threads on the capacitor it says kzg)I have a bit of a variation of the voltage.SO I am wondering if there is soemthing that wou;d be better than this chemichon(I was reading about the sanyo os-con).Pls reply cause I would really liek to change it to something better.Thnx.
Need help pls.
Re: Need help pls.
Welcome to this board. I can only offer you a link to a thread you may have over looked.
https://www.badcaps.net/forum/showthread.php?t=1507 -
by XIIIHi, I bought a gigabyte g5 kc from a friend of mine for cheap cause he forgot the bios password, my main issue is that he changed a lot of things in the v core settings which led to the pc overheating liek crazy, i have a dump from the bios file and i wish to get some help removing the bios password
MOBO S/N 1TNH55DP1250306
P/N 6-77-NH55DPQY-DO2-3D
LAPTOP S/N SN21251J002692
P/N 9RC45KC02CE1E1FR501...-
Channel: BIOS Requests ONLY!
by Caly411Hi, Im having a similar problem with my Acer Nitro 5 AN517 52, took it to repair and they said that the problem was a burned mosfet wich has written on top "I6 GUE 8v1507".
There is written PQB12 on the motherboard right next to it.
Does anyone know if there is soemthing similar I can buy to replace it with?
Seems impossible to find theidentical mosfet online. -
by dicky96I got four replacement batteries for these HP laptops about a year ago. The originals would not charge, and these replacements have now gone the same way.
I'm not sure what the expected life of a laptop battery is but I woud have thought they would last longer than that
I now need to order four more batteries. Possibly these replacement ones were now good? The owner does not mind paying a bit more for originals or good compatible batteries that last longer
The top one is the original
Any ideas?
Cheers... -
by jeremy1976Hi everyone, I have a Samsung giving me issues....It is a "one connect" with the box. I power it on and i get no sound or display. If i power it on with out hooting up to the one connect i do get a display showing to hook up the one connect box. I also get a flashing red LED in the lower right that flashes like once then a quick flash then 5 more flashes...the TV will try to power on two times before the red IR LED starts flashing. I have removed all the boards one by one and inspected the solder joints and capicators and all are good. any help woud be greatly appriciated. Thanks Je...
by cortexiaI woud like to replace the current caps on this motherboard (currently Chocon) with better quality ones. I seem to have access to a wide range of Nichicon at good prices. Could someone please help me in the selection, I am new to all this tech stuff and want to make a good choice. Ideally, I would like to replace all the caps with the same brand... the current caps are as follows:
7 X 6.3v 1500uF - short (Have Rubycon ZL)
8 X 6.3V 2700uF - tall (Panasonic eeufcoj272s)
4 X 16v 1000uF - short (Rubycon yxf)
Please notice the types I have writen in...-
Channel: General Capacitor Questions & Issues
- Loading...
