Re: Gigabyte GA-8IPE1000-G, rev4.0 "problems"
Here is an update. Yesterday, while PC was on and Windows started some schedule tasks including disk defragmentation, I noticed that same squeal noise from the CPU area while HD was under heavy duty. So, I remembered that I had another HD lying around and came to idea to see if this would happen with it, too.
So I replaced the HDs, and to my surprise, the noise was GONE. It wasn't present at Windows Logon, nor during HD activity.
The HD causing the noise is WD2500, and the older one not causing the strange noise is WD800, both are ATA and of the same brand. Could it be that the motiherboard reacts in this way to this HD alone? Or is this older WD800 HD less demanding and does not stress the power as much as the WD2500 one? Or maybe the capacitors near the CPU are just left in good enough shape to keep working with older disk, but are stressed with larger one and then produce the noise near the CPU/VRMs?
Now I am completely perplexed. I have checked this WD2500 with WD's "Data Life Guard" program using an Extended Disk Check and the results showed no errors. All S.M.A.R.T. parameters also say PASS.
I don't have a third HD to see how it would go with that. I wouldn't want to replace the caps only to find out they needn't be replaced...
What do you think could be here?
