Gx270
  • ch0rx
    • May 2006
    Gx270
    I have a GX270 *sigh* and the inevitable happend to me a couple months ago, caps blew on me. I can't ask dell for help because I bought the computer off my dad when his buisness went under and I use it as a home pc... but they said since I bought it off sombody I have to ask them to replace the stuff. I didn't replace the caps at first because I don't know anything of recapping and stuff like that, and I didn't want to send it in to a repair servace... I want to know if you can tell me what cap set to buy, and give me a quick guide how to unsolder the bad ones and put in the good ones, I would greatley appreciate it, for I need the computer functional again, thanks in advance.
    ~Richard
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Gx270
    can you please read this and then come back with specific questions.
    The Recapping FAQ
    you will replace all nichicon HN or HM series capacitors on the board. you can read the values off the caps, they will have capacitance in uf and voltage in v written on them. you will replace with the lowest esr caps you can find that are the same uf an v rating. send pm to Topcat to get a price for caps. or otherwise check the following link.
    Where to buy capacitors and what capacitors to get
    you will have a row of caps next to the cpu, you will need 8mm width caps to replace those otherwise it will look ugly if you use 10mm replacements.
      by momaka
      03-12-2025, 03:42 PM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • edith
      Caps and how to find one to replace
      by edith
      Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
      Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
      Thank you!
      06-11-2023, 05:00 PM
    • madscientist750
      Replacing electrolytic caps by solid caps on old motherboards
      by madscientist750
      I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
      I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
      I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
      10-19-2025, 06:10 AM
    • Mattz_GT
      Which caps to replace: ECS P4M800Pro-M V1.0A
      by Mattz_GT
      It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
      I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
      Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
      Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
      PS. Additional diagnostic,...
      01-22-2025, 12:12 PM
