The caps are marked with big letters D.S, 470uf 10v and what appears to be series marking which is sg. I tried to google them and search them on the forum but no luck so far. Pls help.
Need D.S capacitor datasheet. Please help
Re: Need D.S capacitor datasheet. Please help
This may help but it seems little is known you can try emailing them?
卓宣企業股份有限公司
地址︰台北縣中和市新生街30巷17號1F
工廠: 台北縣汐止市環河街194巷5號3F
電話︰(02)2226-2113, 2225-8482
傳真︰(02)2225-8478, 2221-8292
資本額︰壹仟壹佰萬元
負責人︰ 黃茂隆
總經理︰ 虞正平
業務經理︰周志雄
商標︰D.S
主要產品︰
鋁質電解電容器、高壓鋁質電解電容器。
公司經營沿革
卓宣公司為一專業鋁質電解電容製造商,自1991年成立自
今,產品廣穫各界大廠好評.目前公司與新加坡Emerges 公
司合作進出口業務,產品銷售東南亞各國及印度.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
Thanks for the help guys!
Hey mariushm I still owe you 5 bucks for those caps you sent me, tell me your paypal to send you the money. Finally got a paypal address but had to use slovenian account...Guns don't solve problems. I'll take 12
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by Agent24I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
It has at least one problem.
The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
I have already ordered a replacement potentiometer, so that's not an issue.
Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
All are CapXon... -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
I know that these capacitor will not last as long as nichicon capacitor...-
by chth96I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...-
- Loading...
