Can anyone identify this capacitor?
  • YAP
    • May 2006
    I've recently been having problems with my router, which I've traced to a capacitor overheating: it's hot, and it's making a sizzling noise too, which I can only presume is not good.
    Anyway, can anyone identify it? It's the black one with a black top plate on it, with what appears to be '|01' written on the side of it, in these two pictures:
    http://i20.photobucket.com/albums/b2...anist/cap1.jpg
    http://i20.photobucket.com/albums/b2...anist/cap2.jpg
    Also, do the three little ''' on the top facing towards the camera indicate polarity? Thanks for any help .
  • Rainbow
    • Aug 2005
    • 1372
    Re: Can anyone identify this capacitor?
    It's probably an inductor, not a cap.
    • tiresias
      • Feb 2006
      • 489
      As Rainbow said, it looks like a coil, and in any case not a cap. If you're not sure what it is, could you look on the PCB for the component's 'ID number' and let us know? (such as Cxxx for a capacitor, Qxx for transistor, etc.)
      • Tom41
        • Oct 2005
        • 336
        • England
        That's certainly not a cap, but the problem could be caused by bad caps elsewhere. Some brands (such as Teapo) tend to fail without any physical signs; the only way to tell is with a capacitance meter.
        One PSU I saw had one of these components elongated to the length of your finger! I can only assume it was running so hot that it melted and dripped down - seeing as the PSU hangs upside down in most ATX cases.
        You know there's something wrong when you open your PC and it has vented Rubycons...
        • BlackBurn
          Help to identify a laptop mainboard SMD capacitor LA-9982P
          by BlackBurn
          I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
          Thank You. Stay Safe.
          Chamara...
          11-27-2020, 08:30 AM
        • chth96
          If I replace with inferior capacitor, Is it No harm to other IC components at all?
          by chth96
          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
          I know that these capacitor will not last as long as nichicon capacitor...
          12-22-2023, 04:34 AM
        • chth96
          How can I test non-polarized capacitor?
          by chth96
          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
