Can anyone identify this capacitor?
  • YAP
    • May 2006
    I've recently been having problems with my router, which I've traced to a capacitor overheating: it's hot, and it's making a sizzling noise too, which I can only presume is not good.
    Anyway, can anyone identify it? It's the black one with a black top plate on it, with what appears to be '|01' written on the side of it, in these two pictures:
    http://i20.photobucket.com/albums/b2...anist/cap1.jpg
    http://i20.photobucket.com/albums/b2...anist/cap2.jpg
    Also, do the three little ''' on the top facing towards the camera indicate polarity? Thanks for any help .
  • Rainbow
    • Aug 2005
    • 1375
    Re: Can anyone identify this capacitor?
    It's probably an inductor, not a cap.
    • tiresias
      • Feb 2006
      • 489
      As Rainbow said, it looks like a coil, and in any case not a cap. If you're not sure what it is, could you look on the PCB for the component's 'ID number' and let us know? (such as Cxxx for a capacitor, Qxx for transistor, etc.)
      • Tom41
        • Oct 2005
        • 339
        • England
        That's certainly not a cap, but the problem could be caused by bad caps elsewhere. Some brands (such as Teapo) tend to fail without any physical signs; the only way to tell is with a capacitance meter.
        One PSU I saw had one of these components elongated to the length of your finger! I can only assume it was running so hot that it melted and dripped down - seeing as the PSU hangs upside down in most ATX cases.
        You know there's something wrong when you open your PC and it has vented Rubycons...
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • BlackBurn
          Help to identify a laptop mainboard SMD capacitor LA-9982P
          by BlackBurn
          I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
          Thank You. Stay Safe.
          Chamara...
          11-27-2020, 08:30 AM
        • Agent24
          Dick Smith Q-1760 linear power supply filter capacitor question
          by Agent24
          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
          It has at least one problem.
          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
          I have already ordered a replacement potentiometer, so that's not an issue.
          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
          All are CapXon...
          10-21-2025, 05:39 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
